Old 04-01-2011, 10:33 PM   #1
2013 25' Flying Cloud
san mateo , California
Rear End Separation Permanent Fix?
Have a 73 sovereign, 31 ft. The rear end flooring was rotted out thus a 3/4" gap from frame to bottom of the upper shell C channel. Though both of the main 3/8" bolts at each corner of the rear were intact the plywood was gone, rotted out. The rear end technically didn't separate beyond the floor thickness of 3/4" but vibrates nontheless and a huge problem.
Here's my question, would it not fix these rear end problems permanently by using stainless or galvanized washers to the thickness of the plywood, 3/4", thru these 2 main corner bolts on the rear end w/ the rest of the rear end support staying the same? The floor will have to be drilled on these 2 corners to the diameter of these spacer washers. So,it's all metal on these 2 main supports, no wood sandwiched between. The dreaded separation issue is permanently fixed!
This I am planning on doing but want to have feedback as to it's feasabilty. thx in advance for any info.
dmand001 is offline   Reply With Quote
Old 04-01-2011, 11:00 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
The rear attachment between the frame and the shell is more complex than that.... there's a bent steel angle plate caught between the frame and the plywood; the upper part of that is riveted between the C channel and the skin.
This plate is likely badly corroded, and the dissimilar metals (steel plate, aluminum shell & C channel & rivets) has likely led to poor integrity in all those components; most of the bolts between the frame, rear cross member and C channel have likely failed.
I would:
* remove the horizontal sheet that slides between the frame and the plywood to which the bumper compartment cover is hinged - this abomination is what wicks water into the confined space under the plywood and begins the corrosion problems. There must be a gap between the hinge and the body - the rear compartment gets wet anyway, and keeping the water out from under the plywood is critical.
* Replace that rear bent plate w/ a stainless one, and add an additional row of proper rivets to the skin. You'll of course need to
drill out the rivets holding the skin to the rear channel to do this if they're not corroded out already.
* replace all fasteners w/ stainless.
It's not too difficult, and most of it doesn't show - but it does mean removing the bottom rear interior skins - which can be difficult w/ those plastic bathrooms.
I'd be happy to take a look at it, or you're welcome to come by to look at ours - we're in Menlo Park :-)
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-02-2011, 05:58 AM   #3
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
I just sent you a PM with what our A/S tech did to fix ours. Please let me know if you need anymore information.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 09-02-2011, 10:59 PM   #4
1972 27' Overlander
Saline , Michigan
Can you tell me what the fix was as well
loechli is offline   Reply With Quote
Old 09-03-2011, 10:50 PM   #5
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
Done.
-Shawn
TAC OK-42
Old 09-20-2011, 09:24 PM   #6
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
I'd be interested in that fix too. I've got the very same issue.
Breadbug is offline   Reply With Quote
Old 09-22-2011, 04:46 PM   #7
1981 31' Excella II
New Market , Alabama
That plate on the rear bumper is what I call a funnel plate. I am in the middle of replacing my rear floor and I plan on getting rid of that plate. The problem is the rubber sealing compound breaks down over time and corrosion plays a part. This area is hidden under the belly band on my trailer. I may get rid of the bumper storage compartment all together. The object here is to keep the water off the rear of the trailer. I will probably do something like a rear banana skin. The rear of the subfloor is very exposed in the corners. It is best to coat the new floor with some sort of waterproof coating. Something like epoxy or polyurathane so if it does get wet is will hold up better. The seal where the belly band is located needs to be very good and maintained. Another leak prone area is where the end caps meet the straight part of the trailer. There is a gap in the C-channel there that lets any leaks or condensation go right into the sub floor. I plan on doing something there like glue in a small section to bridge that gap.
You may or may not have to replace the bent steel plate at the back. Mine was rusted but turned out fine after some cleaning a coating with POR15. If you drill out the stock rivets put back bucked rivets not pop rivets. That area is a structural element and needs real rivets. Also the pink fiberglass acts as a sponge and rots your frame and sub floor. I got rid of it and am considering alternatives. Another thing the bumper compartment does is funnel any water than gets in there up under the belly skin where the pink stuff sucks it up. Pull the belly skins and check the frame.
It is best to leave hidden areas of the sub floor uncovered so you can inspect and it also allows it to dry out. I am going to attach my belly skins with screws so I can get under there ever so often and see if there are any problems.
Perry
Old 05-27-2012, 09:51 AM   #8
Medford , Oregon
Done.
Quite a bit of time has lapsed, but I would really appreciate the "fix" you past on last year regarding the rear end subfloor replacement and rear storage hatch dysfunction.
Thanks, in advance;
Richard and Della
'73 Overlander 27'
Della is offline   Reply With Quote
Old 05-27-2012, 09:57 AM   #9
Medford , Oregon
I would:
- Bart
Bart;
This was the first time I had heard the sad truth regarding that bent plate assembly for the rear hatch. A friend and myself looked at that shortly ago and kept wondering why all those materials and why the obvious flaw in how water might travel inside in that area. I had not come up with an obvious fix and your entry nailed the problem. I still do not see what besides the vulkem or the likes, will keep water from flowing back in to the edges of the subfloor. Can you offer any more advice.
Thanks, in advance,
Richard and Della
'73 Overlander 27' (rear bath)
Old 05-27-2012, 07:05 PM   #10
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
Done as well.
-Shawn
TAC OK-42
Old 05-27-2012, 09:03 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am considering replacing that flat piece of metal with a 90* angle piece that is turn out to use for the hinge fastening point. I am also going to coat the plywood with something that will keep it from rotting and/or absorbing water. I am in the process of hauling the whole rear end out of my 1975 rear bath. Only about the last 4" of the plywood is bad, but the tank support frame is pretty well trashed and the rear aluminum channel is in at least 3 pieces and needs to be rewelded. So out it all comes.
Aaron
WBCCI #XXXX AIR #2495
Old 05-28-2012, 05:08 AM   #12
Ludowici , Georgia
Images: 43
mine done the same
Could u send the pic to my email so i can look how they did it please?
Stoney is offline   Reply With Quote
Old 05-28-2012, 05:46 AM   #13
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I coated the top and bottom of the new plywood I installed in the rear of my Trade Wind with 2 coats of West System epoxy resin. I coated in all along the edge and inward for 8 inches. This is a product used extensively to build and repair boats. I built a new cross member out of 2 in angle instead of flat stock. I notched the ends to the top of the angle would be flat with the rails and the ends would extend to the sides of the rails giving me a lot of surface to weld. After I welded it in place I painted it with several coats of rust proof paint from the Eastwood company (Por-15 would work just as well). This was to prevent the aluminum from touching the steel as much as possible. With the leaks fixed, the rear stays dry now and it should be good for many years of camping (a lot more than I'll be around doing the camping).
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-28-2012, 06:42 AM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Why don't you just post the information here in the thread, and share it with the group?
What's the big secret??
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
China toilet and rear end separation nukefamily Sinks, Showers & Toilets 0 02-01-2011 09:37 AM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 08:36 PM
