Old 09-26-2006, 09:00 PM   #1
1974 31' Excella 500
Bremen , Alabama
Question Rear End Sag Not Separation
I have a 31' 1974 Excella 500. It sags from just aft of the rear axle. I am in the process of removing the interior to replace the floor and repair the frame. Only the bathroom is left and I should have it out by the weekend and then I can start on the repair.
I have searched the forum and found a couple of references. They talk about rear end separation, but that is not my problem. My frame is slightly bent just aft of the rear axle. This damage may have been caused when the previous owner made a trip from Alabama to Alaska.
Someone mentioned a TSB (technical service bulletin) and an upgrade kit that could be purchased from Airstream to repair this condition.
Has anyone else had this problem? How did you go about repairing it? Has anyone purchased this upgrade kit from Airstream -- can you give me information about how it worked out? Does anyone have any information on this to help me out?
Thanks for any help you can give.
airstream74 is offline   Reply With Quote
Old 09-26-2006, 09:06 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Airstream got a little "wild" with the weight savings and made the frames on the 70's trailers a little "light". There's a kit out there to beef the frame up in this area. Some guys say it fixes it, others say it doesn't.
Later on they made the frames deeper.
My own 31' shares this malady. I plan to make a new frame for it with a deeper and much stronger section. But if you don't want to go to that extent, you can add doubler plates to stiffen your's in that area. There are some photos on this board of the factory setup. Or, you could design your own. Bottom line is that the frame isn't stiff enough as the factory sent it out back then, and you need to increase the stiffness.
If you do some searching, you can find some posts on here that show photos of the factory fix. As well, it'd not be so hard to design one.
If you'd like help desiging a doubler, shoot me an email and I'd be glad to help. But, a lot of guys say the factory fix is a pretty good one. It's worth looking at that one too.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 09-27-2006, 05:14 AM   #3
Bremen , Alabama
Thanks for the help.
I have been searching but have not found the photos yet. Got any hints on what key words to search under.
Old 09-27-2006, 11:05 AM   #4
JimGolden's Avatar
Check this thread out.
http://www.airforums.com/forum...g+repair+plate
It doesn't have the photos, but it's a good starting point. Those photos are on here, it'll just take a bit of searching to find it. Inland RV might actually sell them, I'm not sure. As I recall it was a bolt on thing. I think people called them "elephant ears" or something like that.
I believe the general consensus is that these plates will fix the immediate problem, but you also need to address other issues that caused the marginal strength frame to be pushed over the edge. Biggies are things like balanced running gear (Inland RV's website gives a very good description of how to do this), and weight distribution internally. Things like don't carry your blacksmith tools in the back, don't tow with full black and gray tanks, etc. Basically keep the back as light as you can, and have the running gear balanced, so the rear of the trailer isn't like a fishing pole bouncing up and down.
That info is all on here, I just didn't have time at lunch here to find it for you. Take a look and if you still can't find it, let me know and I'll dig some more for you. But I'd do searches on "rear sag", "ears", elephant ears", "frame plates", things like that. Also check out Inland RV's site. That should get you pointed in the right direction.
Good luck!
- Jim
Old 09-27-2006, 11:53 AM   #5
Pet Sitter Extraordinaire
kposey's Avatar
1975 27' Overlander
Chattanooga , Tennessee
Images: 56
PizzaChop has dealt with this problem. You might want to do a search on the members list to find his web pages.
Kathy, Tommy, & Crew, Chattanooga, TN
Air #2757
1989 SquareStream (Annie #8)
kposey is offline   Reply With Quote
Old 09-27-2006, 03:02 PM   #6
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Airstream74
My '74 31' sov has the elephant ears on it, which is a sheet metal patch/ cover where the unit was repaired at the factory. I can send you pictures if you would like. The elephant ears were installed after the factory (usually Jackson Center from what I have heard here) has cut out the sheet metal at the rear lower corners to re-attach the floor to the frame. That being said my unit does not have separtaiton, but I do have a bit of sag.
Dave
drag'nwagon is offline   Reply With Quote
Old 09-28-2006, 04:57 AM   #7
Bremen , Alabama
Thanks for the information everyone.
JimGolden - Been searching but so far the only photos I have found were the ones from PizzaChop. If you happen to run across the others please let me know.
dragn'wagon - yes, send the pictures, like to see everything I can before I start.
Thanks again everyone -- and if anyone else has any information or photos, please let me know.
Old 09-28-2006, 06:15 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Airstream 74,
If the frame is actually bent you will need to correct that no amount of floor repair or rebolting is going to cure that. I have attached a couple of pictures of what I am aware of being frame issues. They were corrected with a stiffener plate that was available from Airstream. Mine has it installed and I am assuming by either the factory or a dealer. BTW these pictures are not of my unit they are some that I came across when researching the issues with the longer 70's units.
Aaron
Name:	broke close small.jpg
ID:	26351   Click image for larger version
Name:	broken small.jpg
Name:	plate small.jpg
ID:	26353   Click image for larger version
Name:	plate started small.jpg
WBCCI #XXXX AIR #2495
Old 09-28-2006, 10:13 AM   #9
Originally Posted by wahoonc
Airstream 74,
Aaron
Your cracked frame and axle mounting plate is a beautiful example of what happens when the running gear is not properly balanced.
That type of damage happens with many many miles of towing.
Repairing the frame and axle mounting plate, and then adding the frame stiffeners, is a great help.
However, in time, all three can again do the same thing.
We have seen that happen many times.
Bottom line again, is that the running gear must be reasonably properly balanced, or else.
Old 10-17-2006, 08:56 PM   #10
Bremen , Alabama
Going all the way - floor and frame repair
Well, back to work on my 31" Excella. The interior is completely out. Interior side panels removed, and have started taking out the floor sections.
Thinking of boxing the frame rails like an old street rod. Wondering if adding the strength to the frame could possibly cause any damage to the shell?
Still pllanning to install the frame reinforcing kit from Airstream. As I understand it, this only reinforces the area between the axles on my trailer. The plates the axles are bolted to appear to be wavy and it looks as though a kink or separation might be forming at the rear most point where the left plate is attached to the frame. The weld appears to be broken at this point and a small pocket is forming between this plate and the frame.
Can anyone give me insight into possible problems or benefits from boxing the frame?
If boxing is a good idea, where should it extend to and from. For example, from the front to rear, from center of axles to the rear, etc., where?????
Any comments would be appreciated before I jump into this mess any further.
Old 10-18-2006, 11:11 AM   #11
JimGolden's Avatar
Boxing the frame will help make it stronger, though not as much as deepening it would for the same amount of additional weight. Deepening it, however, would require some other changes (new belly pan, have to do something about the banana wrap,etc.)
The stiffer the frame, the less it will flex, and the less load you dump into the aluminum shell. I've heard it said that too stiff a frame is bad, but I disagree. If the frame were infinitely stiff, that'd be great, provided the suspension works correctly. It's the suspension's job to take out the bumps. So, a stiff frame is a good thing, with a properly set up suspension (aka not too high a spring rate, correct shock damping).
I'm currently enrolled in a welding class and am having a ball. My plan is completely new frame with several key design changes from OEM. A lot of work, but it'll be fun
Good luck with your Excella!
- Jim
Old 10-18-2006, 09:08 PM   #12
Bremen , Alabama
Thanks for replying, it's nice to have someone to bounce things off of.
Changing the depth of the frame seems too drastic (my wife can't believe I said that - she thinks the total destruction I have already done to the interior was too drastic).
Got any ideas on on far I should go with boxing the frame (just forward of the axles or all the way to the front)?
Plan on using 1/8th of an inch to box the frame with and to add a few more outriggers.
Any other thoughts or comments?????
Old 10-19-2006, 07:15 PM   #13
JimGolden's Avatar
Most of the problems seem to be just forward of the axle mounting plate, and then basically the whole way to the rear (although mainly just aft of the axle mounting plate). You might just box from the back bumper to about 4 feet ahead of the frontmost edge of the axle mounting plate. Although if I were doing it, I'd probably just do the whole thing.
The stress is greatest around the axle plate ends and decreases as you go toward each end (front and back).
If a guy wanted to really build an efficient frame, he'd take some flat plat that's about 9" deep right between the front and rear axles, say make it 9" deep the whole way along where the axles will mount (say about six feet of length at 9" deep), then taper it to about 5" deep at each end. Then weld the flanges onto this tapering web. You could even punch lightening holes in the web.
However, that's an awful lot of work to go to to save probably 50-75lbs. Much easier and cheaper to just use an off the shelf available cross section.
It'll be a fair amount of work to box the frame as you've described. What will you do about the crossmembers? Will you cut them out, shorten them, then reweld them to the boxed in areas?
You've got a good idea. I think it'll be a good amount of work; maybe as much as making a new one, but at least you won't have to pull the shell.
Take care,
- Jim
Old 10-19-2006, 08:23 PM   #14
Bremen , Alabama
You are right, the worst spot is just aft of the axle mounting plates.
The suggestion about using a 6 foot long 9 inch deep plate spanning the axles is essentially what I thought the airstream reinforcing kit did. Is that true, do you know?
In regards to boxing the frame, I had planned to buy 20 foot lenghts of 1/8 x 5 inch mild steel (hot roll) and cut to fit between the cross members on the frame rails notching them to fit the cross members, and welding them to the cross members. Would this not work?
Also, did I read somewhere that boxing would be stronger if it were not welded solid but rather stitched -- weld a few inches, skip a few inches, weld a few inches, etc. (this makes no sense to me, I can't understand how it could be ), is this true?
I will try to take some pictures over the weekend and bore you with these too. Maybe you will see something I don't see.
Thanks again.
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
Rear End Sag JimGolden Repairing/Replacing Floor &/or Frame 7 11-09-2005 09:20 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
