Old 12-26-2006, 05:48 PM   #43
1974 31' Excella 500
Bremen , Alabama
Thanks Andy. If I understand you right, straighening the axle mounting plates , rewelding the broken weld, and installing the reinforcing plates will restore the original strength of my frame. And I don't need to worry about the four 1/8th inch holes rusted in the frame. Is this right or did I miss something?
If it matters, besides the broken weld, I think most of the damage was the result of bad axles.
Thanks again for taking your time to help.
Airstream74
airstream74 is offline   Reply With Quote
Old 12-26-2006, 07:43 PM   #44
Airstream74
Bad axles will eventually damage the frame as well as the shell.
The plan as you outlined is fine.
After all the rust has been removed, then and not before then, add the steel plates. That will assure you that the rust wasn't covering something.
When your done, coat all the steel work with at least two good (dripping) coats of underseal.
You should also check for any rear end separation. Typically, when severe damage to the frame has occured, as in your case, some rear end separation also takes place. Any vertical movement at the rear is not acceptable.
Old 12-27-2006, 10:31 PM   #45
Bremen , Alabama
Andy, Thanks for the help. Now I just have to get back to work on it.
Airstream74
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 07:02 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 09:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 10:40 AM
Rear End Sag JimGolden Repairing/Replacing Floor &/or Frame 7 11-09-2005 10:20 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 11:22 PM
