Old 11-27-2013, 03:09 PM   #1
1972 21' Globetrotter
Wylie , Texas
Rear end plate over or under plywood?
My floor was too rotted to tell. Am getting ready to reassemble. Does the plywood back into the rear end plate or go below it?
rippie is offline   Reply With Quote
Old 11-28-2013, 07:12 AM   #2
Mixter's Avatar
1976 27' Overlander
The rear plate goes under the ply.
Mixter is offline   Reply With Quote
Old 11-28-2013, 07:25 AM   #3
Baltimore , Maryland
use a barrier between the plate and the skin when you put it back together. Some use a spray on material such as bed liner. I use a phenolic sheet.
Old 11-28-2013, 09:06 AM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
In addition to what Frank posted, primer and a good sealing between the layers is also helpful.
Old 11-28-2013, 10:50 AM   #5
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I threw out the rusted piece of junk that came out of mine and replaced it with a piece of aluminum angle (6061) opened up to the right angle. Seems to have worked fine, and the only steel to aluminum joint is on the frame. Now I don't have to worry about the skin disappearing around the rivets.....Phil.
pgr32e is offline   Reply With Quote
Old 11-28-2013, 01:04 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"Phenolic sheet". If you know where to find source..please share.
Otherwise, these are seen as "Unobtanium"!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-28-2013, 01:59 PM   #7
1981 31' Excella II
New Market , Alabama
Look at mcmaster.com. Kapton sheet would be better or Mylar for that matter. You probably only need a few thousands thickness.
Perry
Old 11-28-2013, 02:45 PM   #8
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I used some peel and stick rubber roofing tape. It's about 4" wide and easy to use. I used it as a separator when I had to bolt steel to Aluminum. They sell it in the roofing section at hardware stores.
http://m.homedepot.com/p/t/202267106.
Silverflames is offline   Reply With Quote
Old 11-28-2013, 07:02 PM   #9
often one has to look outside the box. Unobtainium is a myth. Somethings are hard to find, sometimes very hard to find, but one can always find if they know where to look...
Phenolic is what plastic laminate is layer onto. At laminate/ cabinet maker supply houses they sell a product called "backer" used to balance the sheet when laminate is laid on a substrate. It is a .025 sheet of phenolic and cost about $12 for 32 square feet. The down side of this is it is not as flexible as I would like.
