User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 10-24-2003, 07:13 PM
trogers713
Mr. R
trogers713's Avatar
Profile:  1984 34' Excella
Rogersville, Missouri
Rear Bath Floor Repair
HELP!!!!!! I just bought a 1969 31' Sovereign to renovate. It has a hole the size of a 55 gallon drum in the bathroom floor. Can anyone tell me how to take out the fixtures ( tub, sink and plastic walls) so that I can repair the hole? Also will the fixtures go out through the door? This trailer is in bad repair, but I would like to see it come back to life. Any help will be appreciated....Tim
Get rid of these ads... register today, it's FREE
Old 10-25-2003, 11:24 AM
gerbermania
gerbermania's Avatar
Profile:
I am currently repairing the subfloor of my rear-bath model. I have all the fixtures out, frame reconditioned, and my next step is to install the new subfloor.
All fixtures will fit out the door, so no worries there.
I bought a 1972 service manual (the oldest available) from Helen Davis of Secretarial Services, and I highly recommend it to you so that you can see how things are riveted and screwed together. It is invaluable when taking out the bathtub and fiberglass components. Just do a quick search on this forum for Helen Davis.
Christopher
Old 10-25-2003, 03:06 PM
trogers713
Mr. R
trogers713's Avatar
That Chris for the information....I will look up Helen Davis and buy a manual...Tim
Old 10-25-2003, 05:24 PM
DKaraisz
DKaraisz's Avatar
Profile:
I also have a bathroom out of a 31 ft rear bath,i took a lot of pix and marked everything. I am now replacing 3 ft of the rear frame and skid plate. I am tring to find the u channel in the rear .It is all corroded and not useable.I enherited this trailer but did not entend on this mouch work. My parents had a lot of fun with this trailer and i hope my wife and i will someday too I am new to airstreams but thanks to this sight i am learning a lot. Doug
Old 10-26-2003, 12:52 AM
gerbermania
Profile:
Rather than "replace" the C-channel main members of the frame, I had the corroded sections of the channels cut out, and then had plate steel welded up as reinforcement.
I used to be able to actually see through the steel, it was so bad. Now it is difficult to discerne the grafted plates from the original C-channel.
BTW: while you are under there, check out the brackets and angles holding up the black tank. Those were severely corroded as well.
Christopher
Old 10-26-2003, 05:32 AM
DKaraisz
DKaraisz's Avatar
Profile:
I had too much rust , i hacked off the whole rear 3 ft on the complete frame, from the last gusset back to the bumper. the u channel i am looking for is the one that goes between the outer skin and the inner. it's the alum. one that bolts to the top of floor. The problem is the alum. u channel has a slight angle to conform to both the skins. I could make one out of steel but dont want to mix the 2 metals.
Does anyone know if regular pop rivits are used on the bottom of the rear skin or olimpic. ITs the part behind the lower alum. band.
When i figure out how to use my camera ill post some pix
Doug
Old 10-26-2003, 06:12 AM
lynn
lynn's Avatar
Profile:
I believe aluminum rear floor channel is still available from the factory. Riveting the aluminum wraps to the floor channel can be accomplished with pop rivets. Make sure they are approx.1 1/2" apart and reseal around rear end and lower rubrail when finished.
Old 10-26-2003, 06:43 AM
DKaraisz
DKaraisz's Avatar
Profile:
Thanks , i do have a call in to indland rv on the u channel and as far as going through hell my wife thinks i am but really i'm in heaven . just dont have enough time for the project i took on.I also have some rot under the door , i dont want to look at that untill the rear is finished
Doug
vB code is On
Pingbacks are On
Rear Bath Floor Droop bdbluegrass All Argosy Trailers 4 05-04-2005 08:44 AM
25' rear dbl ctr bath? FlynG Our Community 2 08-26-2003 04:25 PM
Rear Bath Upper Wall Cracking w5wi General Interior Topics 0 07-20-2003 08:13 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 05:09 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
