Old 06-09-2010, 06:45 AM   #15
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks 62Overlander. I do not understand the part about routing out the subfloor.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 06-09-2010, 06:50 AM   #16
Baltimore , Maryland
if the plate is under the subfloor it will keep the plywood up off the frame the thickness of the plate. By routing it out you will make the plywood sit flat.
The ONLY floor rot I have found. Anyone have a quick fix idea? WILDRTEXAS Repairing/Replacing Floor &/or Frame 8 03-18-2010 06:30 AM
quick silly question! EoinmcCabe Buyer Guidelines 5 02-05-2010 07:17 AM
Quick Question Sheridan Hitches, Couplers & Balls 4 06-03-2009 08:09 PM
Quick boondocking question.... Kestrell Water Heaters, Filters & Pumps 8 07-30-2005 08:20 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 07:21 PM
