Old 02-21-2013, 08:38 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Quick C channel question
Hi all,
A quick question. I am currently taking out a section of the rear bathroom floor all is going as well as expected. I was surprised to find, from the battery box to past the curve of the corner and likewise on the opposite side there is no c channel for the floor to slip into. There is only the one that sits on top is this correct? I thought the C channel is where the strength came from and provided some water protection to the edge.
Thanks in advance,
Tony S
Rogue River, Oregon
Tony S is offline   Reply With Quote
Old 02-21-2013, 08:42 PM   #2
Central , Mississippi
Tony - what year is your trailer? the "C" channel design changed over the years...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-21-2013, 08:45 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Rear flooring sheet end is clamped between the single-C-channel and frame cross member..
Two gaps in the rear single-C-channel for the Battery locker and water heater...
The "double-C-channel" begins at the end-cap seam to only exist on the straight line wall runs.
EDIT - The shell is stiff enough on its own to be said to 'hold the floor/frame up". The side double-C-channel helps spider web connect all the outriggers and keep the floor from deforming. The shell endcap single-C-channel has the main ladder frame to tie into with a much shorter span, the rear has to flex if/when the L/R back frame bottoms out.
Old 02-21-2013, 11:19 PM   #4
1973 25' Tradewind
Beautiful , Oregon
It is a 1973 Tradewind, sorry about that. Thanks for the quick responses back, it keeps me rolling. I am afraid to stop or I might not keep going. Not really but I know it is a long road.
Many Thanks
Tony
Old 02-22-2013, 06:13 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, there was none on mine, either. well...one short little chunk of it, just aft of the wheel well on the street side. (corresponding spot on the curb side is where the battery box is, so...none there.). It doesn't appear to to me to serve much of a purpose.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
