Old 05-30-2008, 07:59 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Quarter round that bends and is plyable
As I am getting closer to putting the laminate floor in my airstream I wanted to share with you a product that I used on my stairs in my house. This is called flex trim. It looks and stains like real wood and it will wrap around an airstream base with easy. Check out the site and check out the quarter round on my stairs where the tread meets the wall. You will see how it bends. My friend thought I used bamboo on my stairs. I used a gel stain on the quarter round and put it on heavy.
Trimster - Flexible Moulding Catalog
Lothlorian is offline   Reply With Quote
Old 05-30-2008, 08:23 PM   #2
denellen's Avatar
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach , Florida
Thumbs up flex trim
Good find. Just getting ready for it.
Thank you.
Dennis
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 05-30-2008, 08:39 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Boy that picture was a shock,I thought he had a 2 story A S.
easyride is offline   Reply With Quote
Old 05-30-2008, 08:43 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
What? Yours isn't?
Vaughan
Old 05-30-2008, 08:46 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Actually, you can bend regular pine quarter round pretty easily. We did it not just with quarter round, but also with big 2" round for a curved staircase. Just soak the wood plenty long enough! (We soaked it in the irrigation ditch.)
Lynn
WBCCI 21043
Old 05-31-2008, 07:41 AM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Not everybody has an irrigation ditch ~
Shari
Old 05-31-2008, 07:56 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hopefully everyone has a bathtub though.....
Old 05-31-2008, 08:32 AM   #8
Images: 59
If you use the irrigation ditch, be sure you chain the quarter round to a stationary object. Otherwise the beavers will drag it off.
Old 05-31-2008, 09:05 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yes, no kidding! We had to tie down everything! On the positive side, the relatively swift current tended to keep the whole of the piece plenty wet.
(Of course, my big brother and I weren't able to throw my spoiled little brother into the ditch when we were soaking wood.)
Lynn
WBCCI 21043
Old 05-31-2008, 11:21 AM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
You may want to consider removing the cabinetry, less tha an hour with a screw gun, and installing the floor under everthing. This gives a clean look and makes installation easy having not to cut around things. If you go this path just drill a 1 in. hole through the floor at each point you are going to screw down things. This alows the flooring to float as per the manufacture.
Yes I did use 1/4 round along the face of the sink but that is under the toe kick and not seen.
I started in the center and worked to both sides after having drawn a sketch of the flooring layout to make sure there was not a strange cut at either side.
ID:	61464   Click image for larger version
2004 Excursion 4x4
Old 06-01-2008, 04:25 PM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
Ok HowieE,
I gotta say, I am impressed that you can remove the cabinetry and in less than an hour. It took me an afternoon just to remove the fold-over sofa in my ’87 Excella. I still have the dinette to tackle.
Your results are absolutely beautiful!!!
Vaughan
The Wheels Go Round and Round wheel interested Our Community 36 11-05-2008 03:59 PM
Bear bends door maxie Doors & Locks 18 08-31-2005 09:43 PM
under trailer quarter panel? 31ftINT'LSOV1974 Belly Pans & Banana Wraps 5 08-09-2003 08:20 AM
Quarter mil A/S Astrodokk Airstream Motorhome Forums 17 06-30-2003 07:54 PM
Quarter Round Molding melprice Floor Finishes 7 09-11-2002 10:59 AM
