10-29-2010, 07:03 PM
1965 28' Ambassador
Irving
pulling channel in
I have been searching for a post that gives a description of a homemade tool with two pieces of channel,some all thread and a turnbuckle to pull the c channel in to secure to the floor.Anyone know what I'm refering to?
10-29-2010, 07:04 PM
1965 28' Ambassador
Irving
Actually two pieces of angle iron and the turnbuckle
10-29-2010, 07:50 PM
Sioux Falls
, South Dakota
I'm trying to guess what you're doing . . .
Gary
10-29-2010, 08:07 PM
1964 26' Overlander
Sugar Land
I was looking for that post the other day, as I just finished that part of my restoration... I was unable to find it, but I found a ratchet strap to work pretty well also. You know, the kind you would use to hold something down in the bed of a truck.
- Chris
10-29-2010, 08:22 PM
1965 28' Ambassador
Irving
shell shift
Gary
The shell shifted out 1/2 or so while installing the floor .Need to pull the sides inand get even on the outriggers.
10-29-2010, 08:24 PM
1965 28' Ambassador
Irving
good idea
- Chris
You could just drop the hooks over the channel and ratchet away.Don't have a helper to push in on the skin.
10-29-2010, 08:31 PM
x
XXXX
, XXXX
the post you are refering to is in Minno's " Little Girl Refurb" thread. Do a member search and look for threads started by him and you'll find it.
10-29-2010, 09:55 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Steve...I looked at the turn buckle "clamp" and wonder why you can't just use a big tie down strap...hook onto either side with reinforcements and ratchet the sides into place.
10-30-2010, 10:59 AM
1965 28' Ambassador
Irving
floor in
Got 2 15 ft. ratchet tie downs at HF for 16.00 Should do the trick,then I can use later.Floor went in perfectly.Glad I did a trial run with $6.00 sheets of Luan.Certainly worth it.Was able to install by myself without the teen helpers! Prodex here tomorrow so I will be toastie when it starts getting cold.
10-30-2010, 02:07 PM
1981 20' International
Shasta Lake City
Look under sub-forums : 1972 Sovereign, "Little Girl Refurb" by Minno. He made a tool to pull his frame together when he replaced his plywood.... trex
10-30-2010, 04:17 PM
1972 31' Sovereign
Lexington
Gee, so nice that you all noticed!
10-30-2010, 05:12 PM
Shasta Lake City
Minno.... I like your thread because your attention to detail in your photo's/log, and the fact that we both have 1972/31' sovereign AS's. It helps to see how to do things the right way. Keep posting Minno, trex
10-30-2010, 05:51 PM
1972 31' Sovereign
Lexington
Thank you! We count it as quite a compliment when people refer to our thread. Chris cobbled that turnbuckle contraption together out of things he had in his workshop - we don't need it anymore so if someone wants to come get it...
Chris isn't posting this because he is currently enroute to Connecticut to pick up our Navy son's trailer to bring home for storage for a couple of years since Navy Boy unexpectedly just got transferred to a sub stationed in Pearl Harbor. Chris said he saw lots of trailers on the road today, but no Airstreams. Oh, we get their dog temporarily too.
Our trailer is closed up for the winter now. We have indoor house projects to keep us busy, and Chris will try his luck at fabricating waste tanks later this winter, but we won't be posting much on our thread. Give you a chance to catch up! (and us!).
Kay
