Old 11-10-2005, 01:17 PM   #1
1968 20' Globetrotter
1988 29' Excella
Jonesboro , Georgia
Price for floor replacement and frame repair
68 Globetrotter 20'
I know, I know, I should do it myself, but I'm trying to weigh all options. I'm in a time crunch for the next 12 months and I do not have a great location.
Has anyone had just the floor replaced and frame repairs done by a "pro" and can you give me quotes? I have everything out so its just cutting the shell, welding the frame and replacing the floor
Do you have to take all the inner skins off to raise the frame?
Dan
68Glbtrotter is offline   Reply With Quote
Old 11-10-2005, 02:06 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
It would be almost impossible to guess at an estimate without knowing how bad your floor is, how bad the frame is, and how much disassembly and reassembly is required. It would be hard to find two trailers that required the exact same repairs, and so another persons cost might not be the same as what yours would ultimately be. Not to mention differences in differet shops. Just finding a shop nearby you would trust to do the work would be a bigger concern than the ultimate cost, because a bad shop could end up fouling you up worse than a good shop that charged more to start with. There's a lot of things to take into consideration.
To remove the body from the frame requires gutting the interior and removing all the lower interior skin panels, to get access to the attachement points. It's a huge job. Are you sure you require an entire new floor, and patches wouldn't suffice?
Stephanie
Old 11-10-2005, 07:29 PM   #3
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Done It Twice In Danielsville, GA
Have replaced rear floor and repaired frame on two units here in Danielsville within the past 18 months.
'72 Overlander
'73 Sovereign
It's a pretty straightforward operation, for the most part, although nothing every goes as smoothly as you'd like. If everything is out of the way, it's simply a matter of shearing off all of the carriage bolts (behind inner skin), removing as much of the old floor intact to use as a template, wirebrushing and reinforcing rusted frame before sealing and painting, and inserting new floor. Take a look at my pictures and you'll see what I mean. The truly difficult part is reassembling the bathroom, bedroom, etc. I'm sure I could do it again but you'd probably have to negotiate the price with my wife.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-11-2005, 12:22 PM   #4
1988 29' Excella
Jonesboro , Georgia
Inner skin
I have already gutted the inside. Pretty straight forward with advice from you guys. All that's left is the h/w htr and the fresh water holding tank. They come out tomorrow. PO had a battery spill in the back, plus the normal bathroom floor rot.
When I got to h/w htr, I found that it had leaked also, more rotten floor. Plus PO had removed the floor in front of the main door and just added some loose boards for safety. I would say that 75% of my floor is in excellent shape. But the places where I can see the frame has me concerned.
Will post pics on this thread tonight.
Keep advice and encouragement coming.
Can you replace floor with shell on and NOT remove the inner skins?
Dan
Old 11-11-2005, 08:44 PM   #5
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Inner Skin
Dan,
You have to remove the inner skin in order to access the bolts that pass through the aluminum base channel into the plywood floor. Even with the banana wrap off, it's tough to get to all of the bolts from the outside. The fun part is that the lowest skin is the first installed so you either have to pull it out of the way or partially remove the next piece up. The corner pieces are particularly fun.
Please post pics...I'm curious...
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-11-2005, 09:06 PM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
You didn't happen to get that Coach from a gentleman in Atlanta Named Marsh did you?
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 11-11-2005, 09:43 PM   #7
1977 27' Overlander
Huntsville , Alabama
Send a message via Yahoo to dustyrhodes
I will be moving my 77 Overlander to the auto hobby shop where I can begin the replacing the floor and working on the frame I am certain is rusted. I have been researching alternate materials and found plastic plywood. It is slightly heavier than plywood but stronger and certainly would never again have to be replaced secondary to water damage. I would appreciate any thoughts on using this material. I fear I am blinded by the Pros and am not seeing the Cons. Pizzachop thanks for the pictures they were instructive.
dustyrhodes is offline   Reply With Quote
Old 11-12-2005, 04:33 PM   #8
1973 31' Sovereign
Portland , Oregon
Images: 22
Dan,
In my case I probably could have removed all of the floor without taking the inner skin off. On my '73 most all of the screws or bolts around the edges were so rusty that I had to cut them off. I had started the floor removal process by sawing out big rectangles of the old floor as close as I could up to the sides and between the bolts down to the frame cross members. I used my circular saw with the blade set to just a hair less than the thickness of the plywood. I used an air powered cutoff tool to cut the bolts or screws either from beneath or by cutting right into the remaining wood strip around the edge. The hardest parts to get out were where the wood was the most instact. Fortunately (or unfortunately depending on your point of view) much of the floor around the edges was a bit rotten.
Attaching the new floor is where you especially need to have the inner skin off. I have wondered if it would be possible to use some sort of expansion or toggle bolts from underneath to attach the floor without removing the inner skin but it might be hard to tell best where to drill the holes. If you have everything else out you will find that it is not all that hard to get the skins out. I suggest you use a permanent market to write on the back side of each piece to idicate where it should go and which end is which. It took a lot longer than I expected before I could get back to assembly of my interior (still not done) and having the labels has been a big help. If you are just removing the lower level it might also be a good idea to add some strips of masking tape on both the piece coming out and the next level up so you can make some alignment marks to help with the install.
Malcolm
malconium is offline   Reply With Quote
Old 11-12-2005, 04:37 PM   #9
1973 31' Sovereign
Portland , Oregon
Images: 22
Dustyrhodes,
I have replaced my floor with a product called Polyboard. Check out the following post for a lot of the details. I do list some of the cons there too. In general, though, I am very happy with the results that I was able to acheive with the product.
http://www.airforums.com/forum...ice-14620.html
I would be happy to try to answer any questions you might have on what I did.
Malcolm
Old 11-13-2005, 06:14 PM   #10
1988 29' Excella
Jonesboro , Georgia
As promised, a few pictures ....
of the floor rot in four places. 1. rear bath; 2. h/w heater; 3. door and 4. my newest location under the fresh water holding tank.
Removing the hot water heater proved to be the most difficult of all items I removed from the AS But that's another story for helpful hints.
The floor is in such good shape where not rotted, I'm leaning toward replacing the back over the black/w holding tank and the front at the door and window. I do not want to remove the belly if possible nor the inner skins...but I will if your suggestions lead in that direction.
Thanks to all who have already responded and no I did not purchase in Atlanta. It came from Florida via Guyton GA.
Dan
ID:	16273   Click image for larger version
Old 11-13-2005, 08:22 PM   #11
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Dan,
I can understand your hesitation with removing the belly pan but given the floor rot, do you really trust the black water tank supports?
I learned with the Overlander and applied the lesson to the Sovereign in that it's best to get everything out of the way for full inspection, repair, refurbish, fabricate whatever's necessary, and then put it all back together. If you're keeping the unit, you'll have more peace of mind in the long run. I know it's a pain and reassembly isn't half as fun as disassembly (I finally reinstalled the rear beltline this weekend on the Sovereign after replacing the floor back in May), but I don't plan to be back into it for at least 5 years (for inspection).
Others can chime in on this one but my advice is as long as you've got it apart, fix it right or you'll regret it later.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-13-2005, 08:41 PM   #12
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
What Ron said. I've learned a bunch from his exprience. That is one reason why I pulled the entire floor out of mine. It isn't sexy, and requires a lot of work, but it paid off. The floor and frame were both compromised all the way thru the trailer and needed extensive repairs. You're probably better off over the long run to completely remove the floor and look at everything. Prob'ly not the best news, but prob'ly sound advice.
www.nesa.org
Air No. 6427
Old 11-13-2005, 09:13 PM   #13
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
I think I'm going to do a body-off frame restoration and floor replacement. I'm in the process of pulling all the "furniture" out of the trailer right now. Then I'm going to pull the interior skin because I want to re-insulate and re-wire.
For the floor replacement and frame restoration, I don't know if I have enough room at home to pull the body off. I think I'd rather do it at our barn at our propery a couple hundred miles outside of town. Then I can just hoist it up and keep it suspended.
But the big question is... is it safe to pull my trailer with the body on, but the interior skin removed?
ankornuta is offline   Reply With Quote
Old 11-13-2005, 09:17 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I patched my floor with the bellypan on. I just replaced the front half of the floor. I did have to remove the inner skins, but don't be afraid of that part - it was the least of my troubles. Probably the worst part was finding frame members that needed to be welded, so I had to hire someone to do it. But still he was able to do the work with the bellypan on. I'm glad I didn't remove the bellypan because the edges of it wrapped up and over the channel, and I don't see how I could have gotten that off or back on easily.
You might be able to get away with some big patches. While the floor is out you can repair any frame problems you have access to. The thing that worried me was that I would find frame problems and end up removing more floor in order to fix them. So you should consider that after you get into it the job could turn out to be bigger than you first anticipated.
Here's the link to my floor replacement project
http://<a href="http://www.airstream...=expensive</a>
Stephanie
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
