08-23-2004, 01:33 PM
1972 25' Tradewind
Lake Worth
Pressure Treated ????????
I was getting ready to replace my rear bath flooring and found out that the new pressure treated wood will not work with aluminum. You will see a warning lable on the wood saying that it has (sodium) in it that will not work with our A/S............
A friend of mine told me that they are having a hard time with nails as well with this stuff. It rot's them out and the fix on the wood has created other problems...................
08-23-2004, 02:12 PM
1965 20' Globetrotter
Houston
And the old stuff had chromated copper arsenate (CCA) in it which is not safe for closed environments and children.
Thats why we use exterior grade plywood for floor replacment.
Nothing is easy.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
08-23-2004, 02:21 PM
LOST
, Hawaii
There's always a learning curve with new materials and methods.
Quick explanation.
John
09-14-2004, 09:14 AM
After soooome research I (and all other assosiated AS people), have found that the product called 'sturdy deck' is the one for the job. it's water resistant adhesive is truley almost water proof. coes in all thicknesses and has toung and groove edges. check it out. Good Luck.
09-14-2004, 09:39 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
well...how about a link to a website, or something? where can we buy it? how much? etc, etc...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
09-23-2004, 08:05 PM
1973 31' Sovereign
Portland
, Oregon
More information...
blnfuse,
There is a lot of discussion in these forums on the topic of floor replacement and what to use. Based on what I have read here it would seem to me to be a bit of an exageration to say that "all associated AS people agree" that sturdy floor is the best choice. Can you give more details as to why you think it is the best choice? Can you provide pointes to forum pages, manufacturer information and etc.? Also did you really mean "sturdy floor" or did you mean called "Sturd-I-Floor" that seems to be made by more than one company?
Malcolm
09-24-2004, 08:18 AM
Originally Posted by malconium
blnfuse,
Malcolm
Sturd-I-Floor is an APA (The Engineered Wood Assoc) designation for plywood or OSB that meets specific performance standards. There is also a specification for Sturd-I-Wall, but nothing for Sturd-I-Deck or sturdy deck. There are several manufacturers.
http://www.apawood.org/level_c.cfm?c...ub_osb_libmain
So, if you're a landlubber you call it a floor, wall, or ceiling. If you're a sailor you call it a deck, bulkhead, or overhead.
09-28-2004, 09:22 AM
I guess that I should have been more specific.
was talking about a product name. I know it as 'Sturdifloor'.
I like this stuff because it is rea plywood and it has ext glue, also the best part for me is the tounge and grove edge (along the lng sides).
It's about 25$ a 4x8 sheet so it's not too exp, and when glued together w/PL 400 it becomes a really good structural addition.
I would shy away from the OSB type of this flooring for obvious reasons.
My plan in use of this in an A/S is to paint the down side with a good quality ext paint before install just to add another layer ofmoisture protection.
Good Luck John
09-28-2004, 12:41 PM
Good Luck John
Sounds like a great plan!
For other people reading this thread, be aware that Sturd-I-Floor is also available as OSB, so don't order it sight unseen. Both the real plywood and the OSB meet the performance specs, so both can be called Sturd-I-Floor. I wouldn't use OSB for a floor, although I understand that even Airstream has used it.
