Old 07-20-2015, 02:11 PM   #1
gYpsydreamin's Avatar
1975 31' Sovereign
Waldorf , Maryland
Prepping for sandblast
I should be ready to have the frame on my 75 Sovereign sandblasted pretty soon here, I have the belly pan dropped but am trying to figure out the banana wraps- I'm afraid of taking them off and not being able to get them back on. How do they come off? Are they riveted underneath of the blue belt? Easy to put back on again? Help!!! Click image for larger version
Name:	ImageUploadedByAirstream Forums1437423059.203884.jpg
(Not blue anymore, but was once upon a time)
gYpsydreamin is offline   Reply With Quote
Old 07-20-2015, 02:17 PM   #2
1971 31' Sovereign
Christine , North Dakota
Check out Minno's "Little Girl Rebuild"
Starting here on page 23 they are reinstalling the belly pan, although in reverse, it should show you how they are assembled.
http://www.airforums.com/forums/f185...-50967-23.html
phlegm is offline   Reply With Quote
Old 07-21-2015, 08:17 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yes, in order to remove your banana wraps, you will need to remove the belt line trim. Once it is off, you will see that the banana wraps are simply pop riveted on overlapping the shell skins. Reattaching the wraps is just the icing on the cake compared to reinstalling the entire bellypan. How is the condition of your floor?
good luck!
Old 07-21-2015, 11:22 AM   #4
1975 31' Sovereign
Waldorf , Maryland
Most of the floor is (very surprisingly) in decent shape with the exception of the rear and a spot near the front, under a window. The rot in the rear is what started this whole project. Started taking the trim off today and doesn't seem nearly as scary as I had imagined.
Old 07-21-2015, 11:23 AM   #5
1975 31' Sovereign
Waldorf , Maryland
And thanks for the link phlegm!
Old 07-21-2015, 02:45 PM   #6
1971 31' Sovereign
No problem.
One thing I have been a little surprised at on this forum is lack of detailed 'how to' articles.
Maybe I just am not looking in the right places?
Old 07-22-2015, 01:27 AM   #7
1975 31' Sovereign
Waldorf , Maryland
I must be looking where you look because I also struggle finding answers to some of my "how to" questions. Plenty of information here but can be difficult to sort through it to find the answer I'm looking for sometimes.
Prepping an Argosy to be repainted RhinoWW All Argosy Trailers 3 07-18-2014 11:08 AM
Trips - Prepping the remotely sited Airstream IanPoulin Airstream Lifestyle 18 05-18-2014 05:16 AM
sandblast argosy? 386kustoms Cleaning, Stripping & Polishing 9 02-19-2013 04:51 PM
To sandblast or grind and POR15 donmyrick Repairing/Replacing Floor &/or Frame 12 11-04-2011 07:48 PM
Tips for prepping the floor for peel & stick MonaxLisa Floor Finishes 6 06-14-2010 07:53 PM
