Old 09-03-2007, 08:47 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
POR versus Eastwood
Thought I'd post this a food for thought. All of the classic car folks at work prefer Eastwood.....
Eastwood Co. - Rust Encapsulator vs. POR 15
Old 09-03-2007, 09:45 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Thanks Gary. I hope this gets some attention - discussion and folks trying it out, then reporting back.
5 meter Langford Nahanni
Old 09-03-2007, 10:26 PM   #3
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Thanks Ganglin.
An interesting article and worth knowing.
I've shared this with a number of the folks in my car club - most of us are somewhere along the path with hot rods and customs and we've all used POR 15. A consideration for most of my group is that POR 15 is available at virtually all of our parts suppliers where Eastwood's products are carried by only a couple and they don't give our club members the same level of discount. I also know if I'm short a bit I can call up one of the buds and "borrow" a bit of what they have on the shelf without having to go buy more. Of course we could order it directly from Eastwood but that would mean we'd have to be pro-active and that word would never be used to describe anyone of our car club group.
I wonder if the Eastwood product comes off exposed skin any quicker than POR 15? Now that would make my wife a bit happier.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 09-05-2007, 03:48 PM   #4
Lenore , Idaho
Images: 51
There is a debate going on over at the Ford truck site: Which is better, Por-15 or Rust Bullet. Long story short, Por-15 requires that you use three of their products for it to work: degreaser,etcher, and finally paint where as with the Rust Bullet you just use the paint (on a clean surface of course) which translates to much cheaper
heybaby1 is offline   Reply With Quote
Old 09-05-2007, 04:32 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Gary, I actually read that article when trying to decide which product to use. Ultimately, POR went on the frame in areas that were not exposed to sunlight. I used the Eastwood product on the areas that needed to be silver in color for the simple reason that I didn't want to paint over the POR.
I have to tell you, I'm not pleased with the Eastwood product. Within a month, I had small amouts of surface rust showing up. I had to reapply in those areas. The tongue looks pretty good. The tail of the Airstream came out ok. I haven't checked closely recently. Maybe I should go back and have a closer look at it.
And yes, I was very careful to apply both products according to the instructions that came with it. I have a little more information over in my "Full Monte" thread.
www.nesa.org
Air No. 6427
Old 09-05-2007, 05:14 PM   #6
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
Clint Eastwood can take POR-15 any day of the week!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 09-05-2007, 05:21 PM   #7
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Thanks Jim for the heads up on your experience.
Basically it would appear that the jury is still out on which way to go, but in my own case to be on the safe side I'll stick with POR15 for now.
Barry
Barry & Donna
Old 09-05-2007, 05:23 PM   #8
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Susan
My wife watched a whole swack of Clint Eastwood movies that were on the satelite station this weekend and I asked her if he was dead or something.
She said Clint can't die as can readily be seen by how he comes out of all the movies - I think they were mostly dusters which she likes.
I was just wondering if you were also glued to the Clint-a-thon this weekend to come up with a statement like that.
Barry
Barry & Donna
Old 09-05-2007, 06:17 PM   #9
Alumatube's Avatar
New Holland , Ohio
No, not a huge Clint fan but think he's okay. The topic just instantly made me think of Clint giving a can of POR-15 a big dent.
That's funny about your wife's reply! Clint will never die!
I did like Pale Rider, but mostly because of the horse...
Susan
Old 09-06-2007, 08:48 AM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
My '73 used an asphalt-based frame paint and neither Eastwood or POR will bond though it, and solvents will NOT easily chase it off, using a high speed rotary wire brush to strip it off (have magnetic sweeper before you start) and a solvent wash 'n wipe and the OEM frame paint still persists... If it aint rusted already you can use most anything to try and preserve the OEM coating - I found Rustoleum flat black merges with it nicely.
Anyhow, I read the link, which I quit reading when I spotted the first flaw - the writer waiting 15-20 minutes for the second coat; the instructions are pretty clear you should wait until the 1st coat sets hard enough that when brushing your fingertip across it there should be just a slight grab or drag from the hardening but 'dry' film; the time is variable depending on temperature and humidity. 3-5 hours seemed right last painting I did, so with such a large error built in the remaining dialog was meaningless...
I can hear Clint asking, where there 15 minutes passed or 150 minutes passed, you feel lucky?
From POR-15 summary PDF on spray application:
In order to form a complete anchor, apply the second coat immediately after verifying the dryness condition of the first coat by touch after 1-2 hours have passed.
Old 11-11-2007, 04:28 PM   #11
1994 34' Limited
colebrook , Connecticut
I have not used either product. So I can't compare them to anything.
I do use Permetex Extend. I have found it to be easy to apply, converts the rust to a durable black finish.
I used it on my old 48 Ply that I drove to work each day on salty roads. It stopped all the orginal rust and prevented further, I had the old car for 8 years.
I does not come off the hands by any methods known other than wear.
malett is offline   Reply With Quote
Old 11-11-2007, 10:41 PM   #12
Hippo's Avatar
Battle Ground , Washington
Gary,
POR works great. A friend was restoring an old car. He painted the parts left them outside overnight the next day they were dry. You could not beat the finish off with a hammer. Really good stuff.
Hippo is offline   Reply With Quote
Old 01-05-2008, 06:23 PM   #13
Jetstreamer's Avatar
1988 32.5' Airstream 325
La Follette , Tennessee
I used POR 15 on my Studebaker Champ pickup, yes the very same one in Garth Brooks "Wrapped up in you" video. 5 years ago I used it on the rain gutters and sprayed top coat on it while it was still wet. It held up outside 24/7 for about 4 years. Fall of 2005 I re-did it using Eastwoods rust encapsulator and the same can of topcoat. It didn't last the winter outside. It looked as if it vaporized with only a trace of it remaining. Good news is I have room inside for the old Champ.
Regards,
Kevin
Jetstreamer is offline   Reply With Quote
4x4 versus 4x2 Tow Vehicle BeBop Tow Vehicles 40 11-24-2007 04:57 PM
06 versus 07 Diesel TVs Streamer1 Tow Vehicles 24 11-22-2006 06:38 AM
God versus Computor... canny_banjo_man Off Topic Forum 2 03-04-2006 11:57 AM
Airstream versus SOB Princer Our Community 9 11-13-2004 08:24 PM
Airstream-Eastwood Action Kistler Our Community 6 01-12-2003 07:01 PM
