Old 05-05-2010, 06:19 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
POR-15 Question
I need to order some POR for treating just the frame area under the bathroom floor of my Overlander. This stuff is rather $$$$$. Would a pint be enough? I have never used it before so I do not know the coverage area.
Is POR the only stuff to use or can I use something less expensive?
Mel
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 05-05-2010, 07:04 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
A pint goes a long way...it'll probably be enough. It really is worth the money - if your'e going to the effort to fix things, do it right.
Shari
Old 05-05-2010, 07:36 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks - 1 pint coming up.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-05-2010, 07:45 PM   #4
1976 24' Argosy 24
Milford , New Jersey
a pint should be plenty for just the back end. Make sure you where long sleeves, gloves and a face shield if your working over head. It's great stuff, but like it says on the can, If it dries on your skin, Only time will remove it. That's pretty accurate. Don't ask me how I know. George
Gkiesel is offline   Reply With Quote
Old 05-05-2010, 08:07 PM   #5
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Have everything ready to paint. Once you have opened the can the whole pint needs to be used at the same time. If you get any in the rim of the can and close it back up you will not get the lid back off. Don't ask me how I know.
Birdwell57 is offline   Reply With Quote
Old 05-05-2010, 08:16 PM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I poured some in a plastic container & used what I needed that way, not out of the can. You can use a baggie across the top of the can & put the lid back on over the baggie for the unused portion. Then, keep what you have left in the refrigerator. Keeps forever that way. Wear a hat too---it doesn't come out of your hair. Don't ask me how I know.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-05-2010, 08:23 PM   #7
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
I have been using KBS Rust Seal works just as good if not better! It's 36.00 for a quart. I thought por-15 was the only product like this, then we found KBS at a car show last month.
John
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 05-05-2010, 08:39 PM   #8
retronotold's Avatar
1965 17' Caravel
1965 24' Tradewind
2005 30' Land Yacht 30 SL
Zeigler , Illinois
I just last week opened up a 13 year old quart can of POR 15. I had used less than half of it back then and sealed it up very tightly, no plastic. There was indeed some on the rim of the can when I sealed it. It took me about 5 minutes of prying to get the lid off, and the recessed rim of the can was pulled upward completely - no resealing the can a second time! The remaining POR now resides in a glass jar, sealed tightly. The can had set in my garage on a shelf for the entire 13 years, going through freeze and thaw cycles each year. I stirred it for a few minutes and it was ready to go.
I painted the tongue of my Tradewind, and time will tell if the POR will perform properly or if it has been compromised. It did take a few days for a small spot to wear off my hand . . . .
The moral of the story - POR is good stuff, and if you don't use it all immediately, seal it tightly and don't give up on it, I think.
retronotold is offline   Reply With Quote
My POR-15 is here! My POR-15 is here! thecatsandi Clearcoat, Exterior Paint & Trim 10 04-13-2010 03:13 PM
How Much POR 15? Bradjun1 Clearcoat, Exterior Paint & Trim 19 09-20-2006 05:07 PM
How much POR 15 rebel beck Clearcoat, Exterior Paint & Trim 19 04-05-2006 11:10 AM
POR-15 Question Jim & Susan Clearcoat, Exterior Paint & Trim 6 10-26-2005 05:15 PM
Por-15 Question: Chuck Clearcoat, Exterior Paint & Trim 8 05-27-2004 05:16 PM
