Old 04-05-2007, 04:09 PM   #1
soldiermedic's Avatar
Florissant , USA
POR-15, and frame repair
Sorry everyone...I am in a huge hurry and didn't use my search button.
Good news on the frame front! My frame will not have to be completely redesigned. There were some major repairs needed though. The frame is rusted pretty well (As all of them are) other than where the new steel is. I am wanting to POR-15. Would a gallon be enough to cover two coats? Should I scale all of the rust off the frame, and take the old paint off of the a-frame and coupler before I POR-15 it?
Should I use the sterling silver topcoat from POR-15 when I am done, or can I use any other exterior paint I.E Rustoleum. Should that be two coats as well?
Should it be brushed, rolled, or sprayed?
Can/ Should the axel be painted as well?
I AM SOOOOOOOOOO HAPPY RIGHT NOW!!!!
Steve
soldiermedic is offline   Reply With Quote
Old 04-05-2007, 05:14 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Congrats !
I think you will be stretching it a bit thin for 2 coats, Good luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-05-2007, 05:25 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Caught me on a caffine jag so here goes verbose post
I am reluctant to strip the factory paint off new axles to just apply POR-15, if yours are old by all means paint them. I am thinking I will use spray rubberized undercoating or bedliner paint on my axles before they get installed...
The inside of frame rails were like new mostly on mine, still the asphalt rubberized undercoating from Airstream that I mostly left alone because it had lasted so well, trying to remove it the fiber discs loaded up very fast and became useless and wire brushes worked but anything left behind oily-paint traces that even after 3 rinses/wipes with brake cleaner spray had film remaining... So all the inside rails and stringers got 3 coats of flat black Rustoleum...
Ouside the ladder frame rails was a war zone on my trailer - no AS undercoating paint left on iron. I went almost to bare metal on mine, sanding off most of the rust and wiping it down with mineral spirits before I painted. I used die grinder with alot of 2" coarse grade fiber discs AND used a coarse 3" wire wheels; the wheel does ALOT of work fast but sheds needle sharp wires. I wore one under the skin of back for a week before it quit hurting (may still be there) and even taped a magnet on my skin trying to get it back out. Before I could use the area again I had to make a rare-earth magnet sweeper to collect the 492 barbs it had strewn all over.
Letsee if I remember this - Using only one quart... (note: 1 qt used for floor 'ON' belly rehab here)
I applied three coats to: Hitch 'A' frame, all accessible iron near black tank, all exposed frame in wheel wells and all exposed iron in steps and all the stringer bottoms that will contact aluminum.
I used two coats on all surfaces outside of ladder frame - outriggers, etc. and two coats on FW tank iron.
I bought 4 quarts, one each gloss & flat black, and two qts of silver. I also bought a gallon of thinner - having brush core damp with thinner sure helps and I thinned the dregs of the quart on last coat as it thickened up from exposure to air. Since I bought four but used just the flat flat black one....
If you want a cheap quart (or two) of silver POR-15 w/ a half-pint can of POR-15 thinner as a bonus send me a PM; its six months young and someone needs to use it soon - if not it goes on eBay.... The silver has alot of solids in it, might be better lasting then the black.
Any POR-15 will need top coat, the 'A' frame on might has got a powdery 'fog' to the finish from UV exposure.... Sanding is required for any top coat to get a bite on the POR-15...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Wabbiteer is online now   Reply With Quote
Old 04-06-2007, 06:29 PM   #4
Florissant , USA
pics of the frame
It looks like the foam spray insulation kept most of the frame in good shape, and without rust. I plan on having the frame sandblasted, and then prime and paint from there.
Here are some pics. Can anyone see anything that should be looked at further?
Steve
ID:	35272   Click image for larger version
ID:	35274   Click image for larger version
ID:	35276   Click image for larger version
ID:	35278   Click image for larger version
ID:	35280   Click image for larger version
Old 04-06-2007, 07:08 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
When I was doing mine I got the advise of a good friend of mine who had a antique car shop.
He said don't clean the rust all the way down to shiny steel.
Take a wire brush wheel etc and knock off all the loose scale, paint, if you look close you can see the paint just ooze into the rust, it will lock on.
Second coat goes very fast as the paint is thin to begin with.
I would buy quart cans and finish the whole can off, rather than gallons.
Also you need plastic sheet under the lid when you close it ot it will never open again.
'77 Sovereign Intl 31' CB
Old 04-06-2007, 08:01 PM   #6
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Buy two quarts, not a gallon. I think three coats are recommended. It self levels very well, so you can use a brush.
Yes, you can use rustoleum over it. I used the aluminum color, not shiny silver, and it has looked good for a year.
Zep
Old 04-06-2007, 08:05 PM   #7
Florissant , USA
With so much foam still clinging to the frame, I was hoping that sandblasting could get rid of the foam remnants and scaling rust.
Old 04-06-2007, 08:46 PM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Doc, here's how I did it: http://www.airforums.com/forum...nte-15132.html Don't EVEN try to read the entire thread, it's tediously boring. Just skip to the part about the frame.
Short answer, since you have the shell off, sand blast it, put two coats of POR-15 on it, Rustoleum over the parts of the frame that will be permanently exposed to sunlight.
Good luck, let us know how it comes out.
www.nesa.org
Air No. 6427
Old 04-09-2007, 03:21 PM   #9
Florissant , USA
What Was Airstream Thinking!
I was looking at my frame as I dropped it off for sandblasting today. I noticed that not all of the crossmembers were the same length apart from one another. I also noticed that several crossmembers were about 1/2 inch lower than the other crossmember that were flush with the main ladder rails. What was the purpose of this, and how should I lay the new floor in?
Next: When attaching the new subfloor, would it be wise to use the elevator bolts like the iriginal with a nut from the underside, or would some wood to metal self tappers be smart?
Last: Reconnecting the shell to the new subfloor. SHould I use a sealant like vulkem under the c-channel to make sure it is water tight? what kind of hardware would you fasten with?
Steve
Old 04-09-2007, 05:14 PM   #10
Bradjun1's Avatar
1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
I don't know why the crossmembers are at different heights. I just did a 62 Globetrotter and the crossmembers were all the same height. I stripped the trailer to the frame, repaired some cross members (which were not evenly spaced. Which is fine) I then sandblasted the frame, brushed 3 coats of POR 15 on. 1 qt covered each layer. The exposed parts of the frame have discolored so I will apply the Sterling Sliver soon. I then reattached a new floor(treated with WEST system epoxy)with wood to steel self tappers. I used way more screws than Airstream used elevator bolts. I did not put any sealant under the C channel. I dodn't think water can get under there. I then glued 1 1/2 inch foil wrapped foam to the bottom of the new floor for insulation. I just couldn't see putting fiberglass back in to get wet and start stinking again. The glass will also hold moisture in the bellypan and cause frame rust and floor rot. I then put new belly skin on and reset the body. I used stainless bolts to attach the c-channel to the floor.Hope this has been of some help. Brad
Bradjun1 is offline   Reply With Quote
Old 04-09-2007, 05:27 PM   #11
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
If you don't have time to use the forum search function you will want to take the time to read the POR-15 instructions for yourself. Bare metal requires a different approach than rusty metal (POR stand for Paint Over Rust). POR-15 never requires a top coat. Adding one is purely cosmetic due to sun bleaching, so you'll only need to top coat exposed areas.
Good luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 04-09-2007, 05:46 PM   #12
Florissant , USA
Bradjun1,
What size were the stainless steel bolts, and how far apart did you place them? did you just replace them in the holes they came out of?
From what I have seen of these crossmembers that were set lower, the original floor had a piece of plywood located in these lower areas to meet the height of the other crossmembers. The floor was then screwed into the lower plywood on the lower crossmembers as well as the ladder edges.
Old 04-09-2007, 05:59 PM   #13
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The lower cross members are for clearance for the floorboard splices. The floorboards should be spliced with another piece of plywood 4-5 inches wide. I gorilla glued and screwed mine. I also installed biscuits (around 3 inches apart) in the splice outboard of the main frame rails.
Kip
Old 04-09-2007, 07:20 PM   #14
Florissant , USA
WIll 4-5 inches be enough?
I assume that the 4-5 inch piece of plywood is what gets screwed to the lower crossmember, and the two boards overlapping at the seam only screw into the plywood on a staggering pattern.
Biscuits are a good plan, but this is a weld shop, and they may not have a buiscut cutter. They could use dowels though.
Steve
Old 04-09-2007, 07:31 PM   #15
Aerowood's Avatar
Arvada , Colorado
No law saying you can't go wider if you want to. I can't remember the exact width of the splice. I also bolted it down through all the layers not just the splice. The splice joint is held together by the glue, the screws just hold it together while the glue dries. I did have to plane the plywood splices to the right thickness. I think it was around .680
Old 04-09-2007, 07:55 PM   #16
Florissant , USA
A nice handheld belt sander would probably make quick work of that once it is in. My skillz on a paint program are slim, but is this what you were describing about the floor? The red dots are where the screws attach the lower plywood and upper plywood together.
Old 04-09-2007, 08:18 PM   #17
Wabbiteer's Avatar
1972 29' Ambassador
You got the joining plate cross-section correct.. six inches for 3" overlap would be sturdy.
Self-drilling machine thread screws were hard to find, Fastenall has them w/ little wing cutters to push through wood easy - just beware the length and amount of thread left after going through those joining plates; my AS from factory had a row of them originally bound by one thread only so they were loose...
Old 04-09-2007, 09:42 PM   #18
Got gandkids?
Doc, these are the old ones, but they look just like the new ones. I got mine at FastenAll.
www.nesa.org
Air No. 6427
Old 04-09-2007, 09:47 PM   #19
Florissant , USA
All the bolts holding my floor down were elevator bolts with a nut on the end. No self tappers at all.
I saw some wood to metal tappers at the local Lowes the other day. Might go look at them again.
Steve
Old 04-09-2007, 10:37 PM   #20
Bradjun1's Avatar
1999 34' Limited
I used the same size that were originally in the trailer and the same spacing. I did put a few extra in. I also used fender washers to help equalize the pressure. Brad
Tail sag and separation Dan Phariss Repairing/Replacing Floor &/or Frame 117 01-29-2013 10:45 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 11:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
