Old 04-19-2007, 06:59 AM   #29
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Then cut it out and weld it up
'77 Sovereign Intl 31' CB
Old 04-19-2007, 09:04 AM   #30
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I am prepared to use Zinc Chromate primer on the aluminum rear flooring channel & ribs & lower shell - It will abrade off where flooring binds along its' perimeter yet be a hidden protection for the rest of channel & shell against any standing water over it's next 35 years or so (I hope) ... The spray product I have is meant for aluminum inboard & outboard motor castings where they see constant immersion
On the frame iron - if it is generalized rust and the iron is paper thin you have a problem, if it is just ribbon areas where welds and the bulk of the beam is intact structurally I would be tempted to paint it and call it a "impact crumple zone" - I am curious what the underneath looks like, the remove-replace treatment is probably best as adding to the existing metal dimensions would interfere with shell, etc..
Tail sag and separation Dan Phariss Repairing/Replacing Floor &/or Frame 117 01-29-2013 09:45 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
