Old 04-09-2007, 06:31 PM   #15
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
No law saying you can't go wider if you want to. I can't remember the exact width of the splice. I also bolted it down through all the layers not just the splice. The splice joint is held together by the glue, the screws just hold it together while the glue dries. I did have to plane the plywood splices to the right thickness. I think it was around .680
Old 04-09-2007, 06:55 PM   #16
soldiermedic's Avatar
Florissant , USA
A nice handheld belt sander would probably make quick work of that once it is in. My skillz on a paint program are slim, but is this what you were describing about the floor? The red dots are where the screws attach the lower plywood and upper plywood together.
soldiermedic is offline   Reply With Quote
Old 04-09-2007, 07:18 PM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
You got the joining plate cross-section correct.. six inches for 3" overlap would be sturdy.
Self-drilling machine thread screws were hard to find, Fastenall has them w/ little wing cutters to push through wood easy - just beware the length and amount of thread left after going through those joining plates; my AS from factory had a row of them originally bound by one thread only so they were loose...
Old 04-09-2007, 08:42 PM   #18
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Doc, these are the old ones, but they look just like the new ones. I got mine at FastenAll.
www.nesa.org
Air No. 6427
Old 04-09-2007, 08:47 PM   #19
Florissant , USA
All the bolts holding my floor down were elevator bolts with a nut on the end. No self tappers at all.
I saw some wood to metal tappers at the local Lowes the other day. Might go look at them again.
Steve
Old 04-09-2007, 09:37 PM   #20
Bradjun1's Avatar
1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
I used the same size that were originally in the trailer and the same spacing. I did put a few extra in. I also used fender washers to help equalize the pressure. Brad
Bradjun1 is offline   Reply With Quote
Old 04-10-2007, 08:27 AM   #21
Wabbiteer's Avatar
1972 29' Ambassador
Just an opinion on the Fastenal screws: Jim's photo of the new fastener shows the winglet cutters that are meant to automatically shear off once screw has perforated metal back-up to whatever wood product is being installed; I thought the extra cutting oversized the mounting hole, did too much damage to the plywood, so know the winglet cutters snap off easily with pliers.
I pre-drilled the floor and spar with 1/8" bits using chalk line after finding the outside edge of spars & used a counter-sink burr on floor surface only where the plywood actually resisted compressing enough to sink screw flush; usually they crush down too far if allowed! The machine thread gives huge leverage so carefull not to punch clear through plywood...
Also about the Vulkem to bond floor to C-channel; I will be thinning vinyl ester resin down with 15% acetone and soaking the plywood edges with three coats to eliminate moisture wicking BUT I won't be sealing the channel - wood interface in hopes any liquid water that made it that far will just keep going and not start a swamp in the sea-channel...
Old 04-10-2007, 08:49 AM   #22
Got gandkids?
Just a clarification on the photo. Those are the orginals in the pic. I used the exact same fasteners on the new floor purchased from Fastenal. They semed to work well the first time around, so I just duplicated what the factory had done.
Around the perimeter (thru the c-channel on the outriggers) I used 1/4 " bolts fastened on the top side with two lock nuts. I also used lots of 1" pan heads in the c-channel as well as at the joints between the individual sheets of ply (over the cross members down into the small piece of wood below).
I used POR-15 on the frame (even after sand-blasting). POR makes a product that is painted on over the clean metal that etches the steel and gives the POR a base to cling to. As expensive as the POR is, it may be cheaper than the epoxy. Just have to compare prices. I gave about $35 per quart for the POR. I paid about the same (I think) for West Marine epoxy, the POR gives more coverage per quart. POR is good stuff and specifically made for this application. I don't think you can go wrong with it.
Just my 2 cents.
www.nesa.org
Air No. 6427
Old 04-10-2007, 05:08 PM   #23
1973 31' Sovereign
Portland , Oregon
Images: 22
From what I could tell on my 1973 31'r the shorter cross-members were 5/8" lower than the top of the main frame rails. I used 5/8" material which fit just fine at that joint. I happen to think that 4" to 6" of spline at that joint is just fine. I used glue similar to Gorilla glue and screws into the splines. I put my elevator bolts in place after attaching the top sheets to the splines. This way they do exert some hold on the main sheets themselves too - not just the splines. I think maybe the bisquits on the outer part is a little overkill but not a bad idea at all. The factory original did not do that and it seemed to work OK.
I used 1/4" elevator bolts in places that I could reach. I left some of my belly pan in place because it was just fine. In those areas the places that I could reach were limited to the part of the new floor panel where I could reach underneath from above to tighten the nut. I did use self locking nuts by the way.
In other places I used Teks Self-drilling Screws which I found at Home Depot. I have attached a photo that shows what they look like along with their packaging. The shorter ones were just fine for most of the work. The exception was mostly for the places where the flooring sits on top of the flange of the outer wheel wells. There I used the longer screws just fine. In most places the screws self drill without a problem. The place where pre-drilling is needed is where the metal is thicker than the standard cross-members. For me this was for the angle iron member across the top of the fresh water tank. It was also for the new rear cross-member that I put it that was also made out of 1/8" thick angle iron.
Around the bottom edges of the body where it attaches to the floor I used either pan head screws or decking screws with nylon washers. It occurred to me that the nylon washer would provide some isolation between the steel screws and the aluminum frame. Also the type that I used fit the bottom side of the flat-head decking screws just fine. I did use 1/4" bolts through the parts of the u-channel at the curves where there is no lower c-channel on my vintage unit.
I also installed the main sheets lengthwise of the trailer frame. This made it easier to get the plywood into the c-channel at the bottom of the walls and it also reduce the number of joints that occur at crossmembers. I added 3/4" plywood splines down the middle of the floor at that new joint.
I also used Polyboard instead of plywood but that is another story...
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 04-17-2007, 04:21 PM   #24
Florissant , USA
Greetings all...please look at this picture of the step area of my frame. This was right after I picked it up after sandblasting. The steal in the step area seems to be torn up pretty badly like swiss cheese.
Can anyone recommend a proper way to fix this area? I know that a piece could be cut to fit, and welded in, then groun to be flat, but I am looking for any options.
Also, I don't know if I should be concerned about the C- Channel. It looks pretty ragged, but don't know if I should have it replaced.
Steve
ID:	35751   Click image for larger version
ID:	35753   Click image for larger version
ID:	35755   Click image for larger version
Streaming Soldiers Blog
Old 04-17-2007, 05:00 PM   #25
Got gandkids?
From what I can see in the top two pic's, the c-channel doesn't look all that bad. Maybe a better/close up pic would help. The step area....
If you don't want to replace the steel around the step with all new, you can buy flat steel plate in approximately that size HD or Lowes and weld or bolt it in underneath the original.
www.nesa.org
Air No. 6427
Old 04-17-2007, 07:23 PM   #26
Florissant , USA
Anyone else have an idea?
Old 04-18-2007, 06:37 PM   #27
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
The C channel isn't that bad use as is.
The frame with the rott....how about a piece of 3/32 or 1/8 sheet steel or alum and just scew it to the old as sister for strenth,
or if it appears to be sound just por it so it can't get worse.
'77 Sovereign Intl 31' CB
Old 04-18-2007, 06:46 PM   #28
Florissant , USA
It's full of holes...just don't want to loose structural integrity.
Steve
Tail sag and separation Dan Phariss Repairing/Replacing Floor &/or Frame 117 01-29-2013 09:45 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
