User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 04-30-2008, 07:06 PM
Zstream
MyFirstStreamer
Zstream's Avatar
Profile:  1963 26' Overlander
Indiana, Indiana
Question Por 15 alternative? How bout Rustoleum?
My 63 Overlander is gutted and ready for rust preventative measures. I do not want the expense of mail ordering Por-15 and prefer to buy a simpler solution...Question... Is there a realistic alternative available? I saw Rustolem Heavy Rust spray today. Anybody have an opinion on Rustoleum?
Please advise. I want to get started this weekend. Thanks to all! Z.
PS- An auto store today recommeded I spray with a primer then use a auto underbody spray...Hows that sound?
Get rid of these ads... register today, it's FREE
Old 04-30-2008, 07:23 PM
denellen
denellen's Avatar
Profile:  2007 25' International CCD
vero beach, Florida
Exclamation Por-15
Bite the bullet. This is no time to hurry up your resto. Por-15 is the way to go. You'l be glad you did.
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
Old 04-30-2008, 07:48 PM
Zstream
MyFirstStreamer
Zstream's Avatar
Indiana, Indiana
When you used Por-15, did you have your underbelly/pan off so you could cover all of the steel? My pan is on and I will not be able to paint the bottom of the steel. Please advise. Z.
Old 04-30-2008, 07:52 PM
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
Valley View, Texas
don't do it
I used it on my Caravels' steel parts. Had rust thru within months. The same result on other parts painted with it around the Ranch. Go for POR.
Old 04-30-2008, 08:30 PM
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby, Texas
Check you local automotive paint suppliers. That is where I found mine and about the same price as online with freight. You might even think about calling paint and body shops. They are the ones who pointed me in the right direction.
Vernon
Crosby, TX
1970 27' Overlander Restoration
Photo gallery
Old 04-30-2008, 08:45 PM
jbond
jbond's Avatar
Profile:  Shalimar, Florida
Epoxy primer is an alternative
If you have an auto spray painter you can use automotive epoxy primer. I've used PPG DPLF epoxy primer to seal an Airstream Frame. Both DPLF and POR15 when dry, seal the metal underneath from air and thus stop the oxidation process. DPLF is a 2 part paint that "chemically" drys or hardens.
I also use POR15. Both work very well. I use DPLF when I can spray the metal and use POR when a paint brush is more suitable. I never put POR in my paint gun.
If you buy POR15, buy the POR solvent to use to cleanup with. I think its lacquer thinner.
Herb
_________________
Wally# 1861
1ST VP VAC
Past Prez of Unit 029 in P'cola
63 Globetrotter Patty
63 Suburban Andy
63 Overlander Tex
62 Overlander Doc
Old 04-30-2008, 09:07 PM
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough, Georgia
If I had Herb's talents, I'd probably try the DPLF, but I'm a rookie I used POR and a product by Eastwood's for the Silver areas of the frame. POR wins hands down. The Eastwood's started to rust thru in spots in just a few months. POR is messy and a bit difficult to work with, but is the best product for the job, IMHO.
I bought mine from a local auto paint store. Check the POR website and see if you locate a dealer near you. Good luck and keep us posted on your progress.
Any significantly advanced technology is indistinguishable from magic. Arthur C. Clarke, C.B.E. (1918-2008)
www.nesa.org
Air No. 6427
Old 04-30-2008, 09:15 PM
wbrownrr
wbrownrr's Avatar
Profile:  2002 22' International CCD
San Luis Obispo, California
Go with the POR. I have used it and I'm glad that I did. You will be happy with the results.
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
Old 04-30-2008, 09:58 PM
Zstream
MyFirstStreamer
Zstream's Avatar
Indiana, Indiana
I see step 2 of the Por15 procedure is Metal-Ready. What keeps Metal-ready from reeking havoc on the underbelly pan? Zinc Phosphate is compatiable with aluminum long term?
Old 04-30-2008, 10:44 PM
urbanfood
urbanfood's Avatar
Profile:  1956 22' Flying Cloud
Venice, California
removing the belly pan.
if you're not removing the belly pan and PORing the WHOLE frame, then you're wasting your time and money, because that's where the rusting out will eventually happen. it's like sealing a window on three sides and leaving the fourth side open for leaks.
take the time to remove the belly pan and use the POR. you'll be glad you did.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
Old 05-01-2008, 05:05 AM
Distantdrummer
Distantdrummer's Avatar
Profile:
As good as Por-15 is reputed to be, there are other measures that could help.
First we all must realize that unless the floor is completely removed that the tops of the c-channel frames will not be reachable for any coating to cover and seal. The rest of the frame channel will prob be less than 100% accessable also. However it is foolish not to do all possible while you have access to the area.
I would try to remove the heavy rust scale with wire brushes and elec.drill motor w/ wire cup . Do not try to brush all way to bright metal. You need a bit of rust for the acid (OSPHO) to do it's work optimally..
Then douse with OSPHO rust converter (about $24 dollars a gallon). Brush it on and spray it where you cant brush with a simple spray bottle. It is water thin and a gallon goes a long long way. Put it everywhere not just on rust areas. It still becomes a great primer even on sound metal. It should be kept out of your eyes but you will undoubtedly splash some on your hands and skin. It will need to be rinsed off you, but not immediately, and is not overly "hot" nor dangerous. Just keep a wet towel nearby while under the trailer. Let it do it's magic for a couple of days, you'll see it working immediately. (it converts iron oxide (rust) to iron phosphate). It also becomes an excellent first primer.But the conversion must be sealed within a week or so at most.
Next get everything covered with red oxide primer (oil based). I'd brush it on, spraying only where I couldnt brush. Zinc Chromate Primer (yellow) would be better but I think it has been outlawed to gen.public.
Put the red oxide on heavy but thin some of it with paint thinner and let that thin paint wick into areas such as the edges of the top of the channel that are non-accessable.
Wear a cap or stocking on head cause your gonna get some in your hair otherwise.
Many people quit here, but idealy another coat of a good enamal should be placed over the red primer after 4 or so good dry humidity days.
The key to all of this is the OSPHO. It is used and touted by many merchant marine users and much of the industrial users on the gulf coast and the oil and refinery industries.
Rustoleum without the first two steps is not the answer. However Rustoleum makes an acceptable red oxide (oil based) primer for the 2nd step. And they make of course enamels for the 3rd step.
I do not think there is ANY one-step solution to successfully fend off rusting metal, for long.
If you are timid about OSPHO there are supposedly alternatives (but I doubt their effectiveness). I have used OSPHO for years with no known harm to myself. Lowes used to sell a copy-cat called Jasco I believe. It is very similar to OSPHO, but why not go with the known brand..? anyway here is a thread for the timid. Also I would suggest a search here in the forums under Ospho.
Sharing my research about how to cure rusty bumpers
.airforums.com/forums/f477/sharing-my-research-about-how-cure-rusty-bumpers-6438.html
Old 05-01-2008, 06:35 AM
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay, Rhode Island
Vintage has some pretty good prices on POR-15 products...and it is at your door 2 days later.
(I love those guys...aren't they awesome?)
Did some POR-15 this time last year, still holding up pretty well, I'll second everyone lese's opinion. Don't skimp. For the average Joe w/out a paint booth, grinders, etc, it is the way to go.
Bill
Life is Good-Camping all around New England
Old 05-01-2008, 07:03 AM
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria, Kentucky
I have tried Por 15. It seems to be a good product but very involved. I have also used Chassis Saver Paint epoxy paint. Seems to be good stuff with less hassle. It can also be found at a automotive paint store.
Paint Over Rust to Stop Rust Permanently With Chassis Saver Truck & Auto Underbody Coating
I have also had good luck with Eastwoods Products but I found the Chassis Saver paint had a lot of body to it filled the pits in the metal.
Old 05-01-2008, 07:33 AM
Ken J
Profile:  1958 26' Overlander
Tijeras, New Mexico
I think it also depends on where you live - here in NM, nothing rusts so I did use rustoleum - if I lived where its wet, would definitely use por 15
Ken J.
1958 Overlander
vB code is On
Pingbacks are On
501 guests how bout signing up and breaking 20,000 jgouras Off Topic Forum 1 04-13-2007 12:16 AM
Alternative A/C for Airstream Bob Thompson Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-06-2006 04:36 PM
Alternative to polishing. bilby05 Cleaning, Stripping & Polishing 9 01-16-2006 03:40 PM
Alternative to zolotone Ken J Upholstery, Blinds, Walls & Interior Finishes 5 10-08-2005 05:40 AM
How bout a Mystic Springs rally update? Moonshot The Rally Zone 3 11-26-2003 07:07 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
