Old 07-21-2007, 06:32 PM   #1
Profile:  1973 26' Argosy 26
Devils Lake , North Dakota
Question Plywood Thickness
Well my Argosy had a solid floor throughout, at least I thought so.
After removing the water heater I found an area about 16" wide and 4 inches deep that should be replaced.
After skiming this section I saw nothing that hinted to what the stock plywood thickness is.
What is it??
After I install it I am going to use that epoxy sealer that absorbs into the rest of the wood. I've already hit the areas that are near water fixtures. Under the sink, under the water pump, etc
Take care
Sundance is offline   Reply With Quote
Old 07-21-2007, 07:19 PM   #2
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 36
Don't know about the Argosy, but my '66 Safari came stock with 5/8ths.
Spiffy Gem is offline   Reply With Quote
Old 07-21-2007, 07:27 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I believe the original was a fairly weak 1/2". Yes, 5/8ths could be close but it's hard to tell with these old dried out, compressed floors. Issues of concern are solid internal veneers -- something for which marine plys are noted. All plywoods usually have waterproof glue. Although it's not 100% water-excluding, I would still treat the perimeter with a high-solvent epoxy like Rot Doctor.
Do an advanced search with me (CanoeStream) as the username and 19/32" as the keyword. You'll find a number of threads -- though I'm not sure this is the total answer.
A useful idea is at Story Stick to copy irregular shapes.
CanoeStream is online now   Reply With Quote
Old 07-21-2007, 08:30 PM   #4
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Hi Sundance, Our 75 26ft Argosy had 3/4 in. plywood and our 79 has 1/2 in. plywood. Just cut back to the good wood and measure it. You are going to have to replace it anyway. Marivn
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-21-2007, 09:11 PM   #5
Janet's Husband's Avatar
Profile:  Eastern , Washington
What is it??
Take care
Well to throw an egg at this project, on both sides of the water heater under the C-Channel there is an extrusion that is attached to the outer skin and the plywood floor slips into a groove on the inboard side. If you are going to replace the plywood all the way to the outside, it will have to be the same thickness as the grove in the extrusion. Our 77 24' rear door has 1/2' ply and the groove will fit maybe 17/32" thick. Just something to watch out for when doing your patch job.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 07-21-2007, 09:24 PM   #6
Thanks All!!
The rot doesn't seem to go wide enough to get to the C channel. Just the area where the hot water heater door sits.
I will have to put on about a 2" overlay of aluminum to patch the very lip from galvanic corrosion.
I have used stuff on the trailer like the Rot Doctor. The stuff I have is Max PCR that I thinned with MEK and it really penitrates the wood.
Old 07-21-2007, 09:43 PM   #7
Images: 13
Pull the aluminum tray in your battery compartment (2 screws). Bed underneath and re-seal the perimeter to the plastic case with Vulkem or Sikaflex 221!
Old 07-22-2007, 07:09 AM   #8
Great suggestion............ will do.
Pingbacks are On
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
Basement plywood removal (not flooring, Al skinned) Wabbiteer Repairing/Replacing Floor &/or Frame 3 09-21-2006 11:34 PM
Squigley Plywood Fasteners: Where? panabax Repairing/Replacing Floor &/or Frame 14 05-06-2006 05:26 AM
Is this the original plywood subloor?68caravel Peter Luger Repairing/Replacing Floor &/or Frame 10 02-22-2006 01:42 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
