Old 03-24-2011, 06:25 PM   #1
1966 17' Caravel
daleville , virginia
Plywood or Advantech?
working a on frame restoration considering
  • 5/8 plywood
  • advantech
  • marine plywood
recomendations?
COACHJEFF is offline   Reply With Quote
Old 03-24-2011, 06:29 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
How much money do you want to spend?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-24-2011, 06:34 PM   #3
1966 17' Caravel
need 4(4x8) will us best product for quality
Old 03-24-2011, 06:37 PM   #4
soldiermedic's Avatar
Florissant , USA
I and several others I know used advantech 3/4". Less warping, moisture resistant, and very strong.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-24-2011, 06:41 PM   #5
1966 17' Caravel
must use 5/8 due to on fram?
Old 03-24-2011, 06:42 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Do a search on Nyloboard too.
Paula
Old 03-24-2011, 07:03 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Paula
I called the Nyloboard company just last week for dealer info in my area. They were nice & sent me samples of 1/2" & 3/4" nyloboard (there is no 5/8"). The nearest dealer quoted me prices of $288 for a 4' x 8' sheet of 1/2", and $429 for a sheet of 3/4" 4' x 8'. That's not including the shipping (since they don't keep it stocked in their store) of $120 something. That's WAY out of the realm of possibilities for my pocketbook--I don't know about everyone else! I'm reading this with interest as well!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-24-2011, 07:10 PM   #8
1966 17' Caravel
i can not afford $1716 and will need to choose
marine plywood or advantech
Old 03-24-2011, 07:41 PM   #9
DanielB's Avatar
Isn't advantech tongue and groove? If so it won't break correctly on 4'.
- Andrew Carnegie
Old 03-24-2011, 07:49 PM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Avantech makes 4x8 sheeting. I checked out the info on their website. Looks all right to me. I am using MGP that I coated with three coats of WestSystem epoxy and three coats of Defthane polyurethane floor finish.
Here is my thread with the post on flooring choices. Good luck!
Lance
Top is offline   Reply With Quote
Old 03-24-2011, 08:04 PM   #11
1980 20' Caravelle
Coeur d alene , Idaho
Find the best grade of Douglas Fir Marine grade plywood you can afford and buy it. I was one of the first OSB reps in the Country and would not use that product in my trailer. Airstream used it back in the late '80's and I believe early 90's and lots of negative comments been made in this forum. PM if you want to know more. Don
glacierrunne is offline   Reply With Quote
Old 03-24-2011, 08:07 PM   #12
DanielB's Avatar
Advantech sheathing is available in both square edge and tongue & groove. The tongue in groove is 4x8 until you slide the tongue into the groove.
With tongue and groove the long edges won't break on 16oc, you have to lay it long-waise to break on the floor joists. Make sure that you don't get tongue and groove.
- Andrew Carnegie
Old 03-25-2011, 06:48 AM   #13
1966 17' Caravel
my floor is 7'6" wide X 14' long
design is to place 1 sheet of sub floor at front 7'6"x3' w/2 round corners and at rear
(I have a frame support at 3' front and rear)
design is to place (2)3'3"x7' at center long-waise
(I have a frame support at center)
this will only create (1) T&G edge at center
(I plan to remove bottom of groove then glue top of goove to tongue)
Old 03-25-2011, 03:49 PM   #14
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Use plywood. I'm a builder and have to use advantech all the time, but i did did not use it on my own house. need I say more. Advantech is junk.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
1958 Overlander- Silk Purse from a Sow's Ear? mkh8911 1954 - 1959 Overlander 56 03-20-2011 05:07 PM
Water Leak in Plumbing eldin Fresh Water Systems 8 03-17-2011 07:43 AM
Aluminum Trim for Plywood Walls Motochi Upholstery, Blinds, Walls & Interior Finishes 7 02-06-2011 09:33 AM
Is it a 'do over' ?? tvanwave Repairing/Replacing Floor &/or Frame 33 01-16-2011 06:13 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 07:21 PM
