Old 03-22-2004, 07:57 AM   #1
Plywood - How thick is the original?
Repairing my floor and had a problem with matching thicknesses of plywood. ANybody know the exact thickness of the original floor plywood on a '61 Safari?
Thanks oh Karma filled veterans.
Marlboro Mafia is offline   Reply With Quote
Old 03-22-2004, 08:01 AM   #2
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
My 62 was 5/8". When I did my floor repairs I purchased marine grade fir. Good luck.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 03-22-2004, 08:17 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My '67 also had what appeared to be 5/8 inch plywood. I replaced it with 19/32 inch oriented strand board (OSB). I plan to level the floor with compound before installing the new non-carpet flooring (can't decide on the exact type yet )
A 1/32 inch difference should not present any problems.
Old 03-22-2004, 08:19 AM   #4
Gordon Watt's Avatar
New plywood could very well be metric.
Gordon Watt is offline   Reply With Quote
Old 03-22-2004, 08:25 AM   #5
Images: 59
Plywood thickness
My 24' '59 Tradewind was 5/8". I plan to replace with Struc1 plywood (plyform, 7 ply) for higher bending strength. Not sure, but I think longer trailers may have used 3/4"?
Old 03-22-2004, 11:31 AM   #6
I am patching at the door and had everything ready to go when I realized my 23/32 plywood was too thick.
One item of interest, I replaced the thin aluminum under the stairs/door with thicker stock and wedged it under the original floor at the seams.
Why? so that when I bolt it down, the old and new will be resting on an equal platform. I decided to do this when I saw that there was a compressed thin layer of insulations between the old floor and the beams near the door.
For the new aluminum I used a "Wrong Way" sign. It is nice and shiney on the back and worked well.
One question---I intend to drill and tap the frame to accept stainless tapered head screws to hold the plywood down. Anyone try this before?
Old 03-22-2004, 12:18 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
i think the frame is too thin and too soft to drill and tap successfully.
Maybe a caged nut would work, if you want to use machine threads.
Uwe
www.area63productions.com
Old 03-22-2004, 02:20 PM   #8
It appears that near the door there is a thin plate tack welded on top the frame rail. Is it steel or aluminum" In your opinion woudl that be sufficent enought to thread?
Otherwise I will have to use toggle bolts or drill all the way through and then put the nuts up from the bottom(which makes another hole to fill).
Thoughts?
Old 03-22-2004, 02:41 PM   #9
Images: 59
drillin' and tappin'
I think the welded in piece you're looking at may be a stiffener that was used to reinforce where the frame was bent toward the tongue. It's not any thickerer than the frame (mine is 14 ga), so I wouldn't try drilling it.
You can barely see it on the frame between the two outriggers that support the step in this picture.
Old 03-22-2004, 02:53 PM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Can you remove or loosen a section of the belly cover?
You could reach around the wrap part and put nuts on bolts. Take out enough rivets so you can push up a bit on the sections you need to get to, this will lift the insulation as well.
I am not sure how your frame runs, in the area to be repaired.
Uwe
Old 03-22-2004, 06:14 PM   #11
As opposed the photo above where the frame bends to the tongue, my is straight.
I thought about sheet metal screws, but you face the same problem as tapping.
I think I have two options:
1) use toggle bolts(larger hole in metal to accept toggles which they butterfly open and hold), or;
2) a hole in the bottom of the frame to reach up with a deep wall socket to put a nut on it.
I'm open to suggestions.
Old 04-08-2004, 10:09 AM   #12
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
15/32
Heres a shot of what I found under my 1980 Excella II after removing the belly skin and (nasty) insulation.
I do not know if this size applies to all years....
Jason
Name:	Original floor.jpg
jjonesnc is offline   Reply With Quote
