Old 09-22-2010, 04:39 PM   #15
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I don't think anyone's suggesting that you buy the cheapest plywood from a home improvement store However, they can order much better materials at very competitive prices.
TX-16
Dave Park is offline   Reply With Quote
Old 09-23-2010, 12:27 AM   #16
CapnTom's Avatar
2004 30' Land Yacht 30 SL
St Petersburg , Florida
Images: 65
Send a message via Yahoo to CapnTom
I used a 3/4" A/C fir plywood for my floor replacement. I was questioning the supplier about marine grade plywood and explained my application. They suggested the A/C Fir. They said it uses the same marine grade resin in the a/c fir as the the marine grade plywood. The difference being the A/C center cords are made with wood chips as opposed to the marine grade where they use solid wood veneers.
After cutting and fitting my pieces I painted the tops with poly, and the edges and bottoms with primer before installation. After the install it sat in the rain for a few days before I was able to put the shell back on and it looked great. No water damage or swelling what so ever. The water beaded up on the poly and the edges were clean and dry. I'd use the same material again. The unit is near completion and and the floor looks great. I used a commercial sheet vinyl floor covering. I have pictures posted so you can check out my progress and floor and such if you like.
Fair Winds and Following Seas,
But If You're Airstreaming let there be lots of Trees.
CapnTom
WBCCI/VAC #2453
AIR #35123
TCT
USAVTN
1950 Liner 22'
2004 Land Yacht 30 SL
2004 Chevy Avalanche
CapnTom is offline   Reply With Quote
Old 09-23-2010, 05:22 AM   #17
1973 23' Safari
Bible Hill , Nova Scotia
Thanks, All
Thanks for your input and opinions- did not answer the hardwood question, but reflects what you and others have stated here before. The floor is after all the last thing to scrimp on and even expensive product is relatively cheap in total, especially 5 sheets for the Safari.
George
SafariGeorge is offline   Reply With Quote
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 05:55 PM
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
