Old 11-21-2008, 09:14 AM   #1
Vernal , Utah
Question Plywood alternative
Hello. Has anyone used a steel, aluminum or composite material instead of plywood as the floor? The meatal decking I have looked at is thicker than the original ply, but I think it would fit with a band on the outside?
I have looked at a few web site and was hoping someone had some experience in this area. Trex or one of its cousins would be easy to cut to size?
LockDry Watertight Aluminum Decking and Railings
Last-Deck Aluminum Decking and Railing Systems
Metal Deck, Purlins, Metal Roofing and Metal Siding in Stock.
GKP4570 is offline   Reply With Quote
Old 11-21-2008, 09:41 AM   #2
1998 28' Excella
Dolores , Colorado
Good morning up in Vernal, Ut.
Hope you haven't had too much winter yet.
Rumors are our winter will start about Thanksgiving.
I believe you would be adding a significant amount of weight if you went to a metal decking. I know you would if you added Trex. I've used some of the Trex 4x4's and they are significantly heavier than a wooden product.
Trex products cut well with band saws, jig saws, etc. so I don't think cutting would be your obstacle.
Good luck in what you decide.
Member Four Corners Unit/CAC
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
Old 11-21-2008, 09:42 AM   #3
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
I recently did a partial floor replacement using Trex trim board (5/8" exact thickness). Look for an article about how it was done in the soon to be delivered Vintage Advantage newsletter.
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 11-21-2008, 09:53 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Airstream tried an aluminum floor in some of the Argosy Minuet's in the 70's. They stopped after a year or two because of sagging that developed between the frame members.
Richard
Old 11-21-2008, 10:10 AM   #5
Vernal , Utah
More ideas?
Durability not weight is my primary concern. Most of my AS use will be dirt/mountain roads close to home. I would be fine with adding some frame members to strengthen to floor or trailer.
Old 11-21-2008, 11:05 AM   #6
Lothlorian's Avatar
Loganville , Georgia
I used a product called nyloboard. I have a thread on this forum about nyloboard and where you can buy it. I have had it in my trailer since mid spring and it has worked great. I left a piece out in the sun and elements all summer and it is just as good today as when I bought it. I have pulled my camper and it has not warped, rotted, cracked or anything negative. I am very pleased. Somebody said it would melt in heat. Mine sat out in the sun and camper through the Georgia hot summers. It has been holding up so far. It will not rot and it does not give off toxic gasses. It is supposed to be fire resistant. Check out the site Nyloboard. Just type in Nyloboard in your search engine.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-02-2008, 07:27 PM   #7
Twotone's Avatar
Minooka , Illinois
I've handled a lot of Trex in my day. If you carry a 20' 5/4 deck board on your shoulder, both ends touch the ground, it's like a wet noodle. It is also very heavy. Also, the 1x's, 2x's and 4x4's are not intended to be used for structural use.
Tom
Twotone is offline   Reply With Quote
Old 12-02-2008, 09:44 PM   #8
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
I went to the nyloboard website, very interesting, but I couldn't bring up specs on the material itself. Is it rigid like plywood or flexible like Trex? Is it as heavy as Trex or as light as plywood?
A good question isn't if Trex is too flexible to use as a subfloor, but how does the subfloor add to the structuraly integrity of an Airstream. I've seen Airstreams with subfloors that are almost completely rotted out, but the Airstream can be towed, even a great distance, without falling apart. Structurally, I believe the subfloor adds structural stability primarily around the perimeter of the floor where the shell is bolted to the chassis through the floor channel. As such, the subfloor fills the space between the shell and the chassis. As long as it remains intact around the perimether the semi-monoque shell stays tight with the chassis. The shell provides rigidity, not the chassis or the subfloor.
Early Airstreams relied on the subfloor for structural strength to a greater degree than the ones built since the early Eighties because in the Eighties the chassis was beefed up and made stronger (and heavier).
Forrest
Out for coffee!
Old 12-02-2008, 10:19 PM   #9
imeynstein's Avatar
Texarkana , Arkansas
A long time ago, I had read in a thread that someone had used some type of marine fiberglass type of flooring...This flooring looked like what people use as a cutting board--white---, but the flooring did not warp, bend, buckle, or shrink....I am sure it has to be pretty expensive though...does anyone else remember this information???
imeynstein
imeynstein is offline   Reply With Quote
Old 12-03-2008, 07:29 AM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Another option
The TrailManor that I had before I went Airstream had a floor composed of 4 bonded layers that was light and rock solid.
The layers top to bottom were: 1/8" plywood, aluminum, foam, aluminum. The plywood prevented damage to the top aluminum layer. Wood strips were placed around the periphery for attachment and wood blocks were placed at strategic locations to attach partitions and the like.
The foam in the TrailManor was 3" thick which made a very rigid floor and permitted a much lighter frame. On an Airstream, much thinner foam could be used.
I believe that this approach could be used on a vintage Airstream with appropriate thickness of foam.
John W. Irwin
WBCCI #9632
Old 12-03-2008, 07:43 AM   #11
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Forrest,
I have samples of the material at Area63. It is much like plywood, perhaps even a similar weight. It supposedly cuts and machines like a high quality plywood. I wanted to use it for the subfloor in my 1958 Flying Cloud, but the shipping charges from Georgia to California far exceed the price of the material. Especially since I wanted a one piece floor. I might still do it, depending on how business turns out in 2009.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 12-03-2008, 07:57 AM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I looked at some of these alternatives to plywood (the floor in a Silver Streak is important, but not crucial, to structural integrity as it is in an A/S), and finally decided that ADVANTECH would be my choice. It is worth a look:
Advantech Flooring - Huber Engineered Woods
Old 12-03-2008, 11:26 AM   #13
2002 19' Bambi
Lafayette , California
Advantech appears to be a high-quality OSB product. The website says:
"AdvanTech Flooring and Sheathing panels are bonded with an advanced resin technology system. Wood strands are mixed with resin and wax and pressed under heat....AdvanTech, like most other wood products, is susceptible to decay if exposed to long term high moisture conditions."
I, personally, think there are many advantages to plywood or OSB floors in an Airstream, but all wood products can rot. A good quality marine plywood, which is easily obtained in most locations, is a very good wood product to replace an Airstream's floor.
Tim A. is offline   Reply With Quote
Old 12-03-2008, 11:53 AM   #14
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
I think the challenge is finding a material that meets a number of different criteria, durability, stiffness, weight, moisture resistance, tensile strength, etc. It is my impression that the subfloor on an Airstream is not unlike plywood sheathing on a stud-framed wall. When you fasten the plywood into the studs, it makes the entire wall more stiff. It's also my impression that the Airstream was designed to "flex" a bit. While it's tempting to go with the "if a little is good, more is better" school of thought, there might be a downside to using a subfloor that has less flex than plywood. While I'm a proponent of using newer, better materials and technologies in travel trailers, I'm pleasantly surprised by how well the plywood floor in our Overlander has held up after 41 years. Yes, the floor has rotted but in areas with water leakage problems, i.e., the rear bathroom and near the entry door. The choice of carpet with pad held moisture against the wood creating a suboptimal environment for durabilty.
My sense is that using a top grade plywood (marine or otherwise), treating it with an appropriate coating system, avoiding carpet and preventing any leaks would allow a person to get 40 or 50 years of good use. As with any engineering question, there is always a cost benefit analysis component. There's no question that one could buy a new composite material... but what are the specific gains over plywood. If the trailer is properly maintained, I'm not sure rot is a major issue.
Since we're talking subfloors, what do you think of this idea. Rather than using heavier plywood with butt joints, why not build a subfloor from two layers of thinner, overlapping plywood. Using industrial adhesive and fasteners, what you would have is a single, unified floor. Just curious.
hampstead38 is offline   Reply With Quote
alternative to plywood re-floor? fotochop General Interior Topics 24 03-02-2018 11:31 AM
Alternative A/C for Airstream Bob Thompson Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-06-2006 04:36 PM
Alternative to polishing. bilby05 Cleaning, Stripping & Polishing 8 01-16-2006 03:40 PM
Alternative to zolotone Ken J Upholstery, Blinds, Walls & Interior Finishes 5 10-08-2005 05:40 AM
Centramatic alternative? bake315 Axles 7 11-18-2004 04:16 PM
