Old 05-16-2016, 12:00 PM   #1
1976 31' Excella 500
Grapevine , Texas
Exclamation 76 excella 500 subfloor problems
My husband and I just bought this '76 airstream excella 500 land yacht! were in north texas - we started renovating yesterday and found some spots that are rotted out it seems.... were NEWBIES in this airstream world of wonder and could use all the help we could get!! I dont think it's as bad as we think it is, no smell at all... but we are worried and nervous! we drove it from south texas and it was raining on the journey so as we pulled up carpet we noticed it was wet in the center. You can see this in the pictures - the darker areas. We think the leakage is coming from the bottom of the airstream OR could it be plumbing? We are not sure... Do you know??? Please help us!!! We are so excited and thrilled to get started with this whole thing ;-) Much love and thank you!
PS- my husband is thinking of getting a fog machine to put inside to see where the moisture is coming in from. What do you think?
Name:	demo day 1.jpeg
ID:	262622   Click image for larger version
ID:	262624   Click image for larger version
ID:	262626   Click image for larger version
ID:	262628   Click image for larger version
mmich21 is offline   Reply With Quote
Old 05-16-2016, 12:37 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It might surprise you, but many of those leaks may be coming from access doors (I see one in the last photo), or a window seal. The water migrates down to the folly. Get it all clean and dry it well with some circulating fans. Wait till you get a rain or wet it outside, in sections, so you can trace leaks. You can also "pressurize the inside with a shop vac or leaf blower. Squirt liquid soap on the outside and look for bubbles.
Old 05-16-2016, 01:27 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
X2 on drying it out. I use a good, wide tape to seal exterior areas I think may be leaking and wait for rain or hit it with the hose, then looks for leaks. I think this is a better approach than sealing all kinds of places and not knowing where the leak is coming from...Leaks will fool you. They are often a long way from where you see water on the floor.
CRH is offline   Reply With Quote
Subfloor Repair Advice please for a newbie Mary Burris Repairing/Replacing Floor &/or Frame 6 10-28-2013 08:23 PM
Need HELP in Tampa- Looking for someone to fix frame/ subfloor in Tampa? Mixter Repairing/Replacing Floor &/or Frame 13 12-08-2012 08:19 PM
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
subfloor in bath help seeflash Floor Finishes 2 10-22-2009 07:13 AM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 03:15 PM
