Old 07-05-2010, 11:12 AM   #1
Dorchester , Ontario
Question Pipe Frame stabilize/reinforcement
I am looking for ideas and pictures to help me repair my pipe frame as having a new ladder frame made without specs is just too difficult.
The 4 inch center steel pipe is good but the crossmembers are all shot.
I was thinking of replacing all aluminum crossmembers with steel ones of the same thickness and size to make it stronger and prevent this frame rot from happening again. Thanks
Vintage One is offline   Reply With Quote
Old 07-05-2010, 12:54 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Build a New Frame
Hi Vintage Kin,
I also own a vintage kin...Avion to be precise.
OK, so the pipe frames were pretty weak. If I were you, I'd build a completely new one.
Use 6" (150mm) deep channel section, with a minimum thickness of 1/4" (6mm). Put a cross piece made of the same material at least every 48" (120 cm) down the length of it. Do this, and you will be fine.
Use your old one for a template.
I designed a new frame for a 31' Excella that was similar to this, but used 8" deep material. You don't need that thick for a short one like your's.
Best of luck, and don't hesitate to contact me if you want more detail. Be happy to help you. (I'm a structural engineer among other things.....)
take care,
- Jim
JimGolden is offline   Reply With Quote
Frame Reinforcement Plates (as preventive installation?) Astroboy Repairing/Replacing Floor &/or Frame 18 10-28-2009 07:37 AM
pipe frame repair eubank Repairing/Replacing Floor &/or Frame 4 05-30-2008 09:03 PM
Frame reinforcement - 1973 O'lander Lothlorian Repairing/Replacing Floor &/or Frame 2 02-10-2008 03:46 PM
Reinforcement of Frame Lothlorian Repairing/Replacing Floor &/or Frame 0 12-10-2007 05:15 PM
HELP -- does a '51 Clipper have a pipe frame? Corraleno Repairing/Replacing Floor &/or Frame 5 12-09-2007 11:24 PM
