Old 07-12-2006, 10:33 PM   #43
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Alan,
When I did my Safari, I used a fine toothed circular saw blade and if I remember right, I cut the boards with the finished side facing down to avoid chipping. No need to mask off with tape that I remember.
On the jig saw with the laminte blade you cut finish up because the blade takes that into account already. If I remember correctly.
You need to start on one side and work your way to the other with the floating floor. On the side your going against, you put spacers in at the wall to maintain that expansion joint. So you start against one side and work your way across. Be sure to stagger the boards. For example the first board may be full peice, next is 2/3, next is 1/3, then start a full peice again. This keeps the joints from lining up.
If you have the foam underlayment already attached you don't put any more on the floor. It's just to help keep the noise and creaking to a minimum.
-Tim
theVAP - Airstream Podcast
Old 07-13-2006, 06:40 AM   #44
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks, I think it was your install photos(?) that gave me the push to do laminate. So you cut the plank lengths into 2/3 1/3 and whole? Makes sense if that is what you mean.
I may lay some out today and see what it shapes up to look like. The underlayment I had was old foam , I rippped it out and cleaned the plywood floor well.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-13-2006, 06:46 AM   #45
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Safari Tim
this link took me to a tele-phone web site
AIR #005
retired!
Old 07-13-2006, 08:49 AM   #46
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Changed webhost....
Here is the new link
-Tim
Could I use '70s Argosy for Temporary Relo? jburnes Airstream Motorhome Forums 9 11-16-2003 12:01 PM
Pergo Floor Installation Windspill Floor Finishes 7 08-27-2003 09:15 PM
"Twin" beds in 70's trailers... Chuck Our Community 15 08-26-2003 03:26 PM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 05:13 PM
