Old 02-26-2014, 04:14 PM   #1
1960 Caravel
Palo Aloto , California
Patterns / Drawings / Blueprints / Plans
Hello, I have a 61 Caravel with no subfloor and a pretty beat up shell. I need a drawing, or template or something to cut a new floor out that I can use as a guide to get the shell back into shape.
Does anyone have accesses to such things? Any scale drawings of any parts would be really helpful.
Cheers, Chris.
Caravel-61 is offline   Reply With Quote
Old 02-26-2014, 06:49 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Chris, unfortunately/amazingly those curves/corners were not "standardized". Even in the same trailer, the Street Side might be a different radius than the Curb Side. Ideally you make a template of the old plywood before tossing it. I know in your case it's long gone. You will probably need to leave it squared off and then drop the shell on the plywood and trace the curve . . . others might lend their advice but I think that's going to be your best option. On damaged corners, I'd pull the panel, beat it out flat, use it as a template for a new panel, install the new panel and then drop the shell for a line to trace . . . the good news is that your shell is pretty light. There are "shell off" threads that you should probably become familiar with. Ask lots of questions.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 02-26-2014, 07:00 PM   #3
65CV's Avatar
Western , Massachusetts
Welcome to the forums, Chris.
Frank Yensan (62Overlander) did a very good tutorial on floor patterns here. Hopefully, you have enough to make the pattern.
If not, others have battled with this problem, but I don't have a link handy. Maybe one of the threads in the links to major renovations would have details. If not, it's a great source of information for you.
Good luck,
John
65CV is offline   Reply With Quote
Old 02-26-2014, 08:31 PM   #4
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Chris,
The plywood on ours was not useable for a pattern. I laid out new plywood on the frame (the shell was off) and used the c channel to trace the curves.
Tim
Beaker63 is offline   Reply With Quote
Old 02-26-2014, 08:34 PM   #5
1960 Caravel
Cheers! I guess that explains why I can't find any drawings for the floors!
One probably stupid questions, are the C sections meant to be riveted to the steel frame or are they screwed to the top surface of the wooden subfloor?
61 Caravel, North CA
Click here for Photos
Old 02-26-2014, 08:53 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Chris,
A recent episode of TheVap podcast covered how to create the sublfoor curves without a pattern. Check out the podcast and take a listen.
Bill
Cheers, Chris.
Just my personal opinion
Old 02-26-2014, 10:27 PM   #7
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Screwed to the Top Surface of the Plywood AND then Bolted to the Outrigger Ends
2012 Airstream current available models and Floor Plans Colonial Airstream Commercial Listings 11 10-08-2011 08:24 AM
Scale plans for early '70s Tradewinds Madmike 1970-79 Tradewind 2 07-30-2011 11:03 AM
1972 31' Sovereign frame drawings Darkspeed Repairing/Replacing Floor &/or Frame 16 05-27-2011 02:47 PM
patterns for a 57 Silver Streak bottom? EBo Vintage Kin 1 02-02-2011 04:13 PM
New plans of bath - WC in my blog... cruiser54 General Interior Topics 1 01-12-2011 05:59 AM
