Parts list for frame repair / subfloor replacement
Hello there. So in about 1 week I'm taking a week off of work to hopefully repair my frame and replace the subfloor on my 1976 Overlander. As it stands, I've removed all of the banana wraps and from what I can see, the rust is superficial. The inside if gutted all the way to the subfloor. My plan of attack is to remove all rivets and bolts securing the shell to the frame, all bolts running through C-channel, subfloor, and frame. I then plan to use an underhoist to gentle lift up one side of the shell, slide the subfloor out as intact as possible to use as a template, set the shell onto shims to hold it up, then hoist the other side up and do the same thing. Then I plan to strip off the rust, use POR-15, place new subfloor, lower the shell back down and bolt through to the frame.
I don't have room or help from friends to set up a gantry so this is unfortunately out of the question. I also don't want to piece together subfloor since I worry it'll screw with integrity.
I'm hoping someone might be able to verify that my idea isn't insane and maybe recommend any parts I might need. For stripping the rust, I have an angle grinder that I was planning to use a wire cup on. That sound ok? Any pointers on how many buckets of POR15 I'll need? I have a 27' model of Overlander.
Any consensus on the best sealant to use on the subflooring? I am still deciding on BCX vs marine grade.
Thank you for any help. I just want to order all specialty items I might need to have delivered this week before I start this crazy process. Thanks!
