Old 11-09-2015, 07:41 PM   #1
1990 25' Excella
Mesquite , Texas
particleboard not plywood
Thank goodness it's in good shape. We're removing the carpet after realizing we're dealing with a '90. One important no-no I hope not to repeat...leaving a bathtowel near the toilet flusher...gravity wins everytime...flood.ripped up cpt.no damage.? Why would there be particle board instead of plywood in a 90 25' excella? Steeerang. Has anyone out there dealt with particleboard? Yes..happy she is dry.
gogonow is offline   Reply With Quote
Old 11-09-2015, 09:53 PM   #2
Mission , Texas
Particleboard or OSB?
OSB maybe ...
Particleboard NEVER (for anything).
nrgtrakr is offline   Reply With Quote
Old 11-09-2015, 09:58 PM   #3
1990 25' Excella
Mesquite , Texas
nrgtrackr
OSB..hmmm
Neva heard of it
Looks like compressed pieces.
TY for telling me abt osb nrgtrackr
Old 11-10-2015, 01:47 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
That vintage uses OSB, not plywood!
OSB is not particle board!
Old 11-10-2015, 01:53 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
FYI/ if you didn't know OSB stands for oriented strand board. I would much rather have plywood but I just put up a new metal roof on my leaky garage. You could see where it was leaking and I was pleasantly surprised the OSB was not in worse shape.
Old 11-10-2015, 01:59 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
The osb actually uses the same glue as the marine grade plywood, therefore it withstands moisture and water soak better.
Particle board is entirely different and lesser spec stuff!
Old 11-10-2015, 02:33 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Yes, the OSB uses good glue. No, the OSB does not withstand moisture and water soak better than plywood. The OSB is hot pressed and the strands are very compressed and there is very little contact area of the glue. When it gets wet the strands swell and it comes right apart. 24 hours in a cold soak test and you have to dip the strands out with a net. Hard to measure "thickness swell" when you can not find all the flakes. Some of the very modern OSB's (last 10 years) intended for floor underlayment use more and better resins and have slightly smaller thickness swell than the older panels but that kind of panel is not what is used in Airstreams. And plywood still does a lot better in a soak test.
I have 2 trailers with the OSB floors. I have done some patching. But overall still in usable shape after 28 years.
The OP could be looking at particleboard if he has the raised toilet on a little box. They used particleboard for that part on our trailer that has that feature. Plus they used particleboard under all the laminates in the walls and counter tops and table. Weight without strength or moisture resistance. Poor choice of material by my standards, but what they used.
Old 11-10-2015, 04:01 PM   #8
They ONLY osb of high quality is
Advantech. It can used in marine applications. But if I had the budget
Coosa board would be my first choice
0557 is offline   Reply With Quote
Old 11-10-2015, 08:40 PM   #9
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
No mater what wood you use, trapped fresh water, and wet wood will cause the wood floor to fail.
sgschwend is offline   Reply With Quote
Old 11-11-2015, 06:34 AM   #10
1990 25' Excella
Mesquite , Texas
Sgschwend...so true...this is why we removed the carpet immeduately. Thankfully there is no damage to the floor.
Old 11-11-2015, 06:37 AM   #11
1990 25' Excella
Mesquite , Texas
Thank you for responding. I knew enough to remove the carpet and pad asap...no problem
Old 11-11-2015, 07:54 AM   #12
1988 25' Excella
1987 32' Excella
Great mystery to me why Airstream puts carpet in the bathroom to start with. I guess it is cheaper than installing a proper bathroom floor.
Old 11-11-2015, 10:53 AM   #13
1990 25' Excella
Mesquite , Texas
I don't know Bill M. The carpet is top notch however, who needs or wants it?
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
Basement plywood removal (not flooring, Al skinned) Wabbiteer Repairing/Replacing Floor &/or Frame 3 09-21-2006 11:34 PM
Plywood floor change. Airstream69Boy Repairing/Replacing Floor &/or Frame 1 01-03-2004 07:25 PM
Sealing Plywood For Floor 63 Safari srgntpepper Repairing/Replacing Floor &/or Frame 38 09-16-2003 09:31 PM
Forget the plywood floor... Robert Repairing/Replacing Floor &/or Frame 0 08-18-2003 05:17 PM
