Old 02-04-2016, 03:15 PM   #29
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The problem described in the initial part of this thread sounds a lot more like a frame failure than the typical rear-end separation common to the 70's era trailers. Good news is, that your frame probably can be repaired/strengthened (which will only require digging into the belly pan) without as much labor and trouble as repairing a separation (which would require removing the interior furnishings and skins in the back).
The bad news about frame droop/failure is that towing for hundreds of miles to a place to have it looked at could cause even more severe damage. Another option may be to look on the "portal" page and see if there is a forum member who volunteers to do pre-purchase inspections in your area. If you could get someone with the properly "calibrated eyeball" to check you out, at least you may have a better idea of what the real issue is and how safe/unsafe it is to tow. Then again, most RV places ought to be able to spot a broken frame--you probably don't have to take your trailer to the mother ship to get this repaired.
You might also contact Area 63 Productions (http://www.area63productions.com/). They are a custom Airstream repair/rennovation shop that might be closer to where you are.
good luck!
Old 02-04-2016, 04:27 PM   #30
2003 31' Classic
Terra Alta , West Virginia
Interesting thread. You have a lot of people who are rooting for you. Keep us posted. We genuinely care.
wvstreamer is offline   Reply With Quote
Old 02-04-2016, 05:38 PM   #31
1967 26' Overlander
Anywhere , USA
I have attempted to find pre-purchase inspectors in the past without much luck. User error navigating the site probably. Can anyone offer me direction on that?
I also have had "join WBCCI" on the to do list for awhile, so will try to check it off the list ASAP. Maybe I can find someone local through that as well.
Thanks everyone!
Warmly, Beth
"wherever we go, we're always home"
Diogenes is offline   Reply With Quote
Old 02-04-2016, 07:49 PM   #32
1969 27' Overlander
Scottsdale , Arizona
Rear End Separation -
Talk about losing your A$$.
Sorry had to say it.
BFSSBN is offline   Reply With Quote
Still safe to tow with rear end separation? cgraver72 Repairing/Replacing Floor &/or Frame 8 05-03-2007 07:50 PM
Rear End Sag Not Separation airstream74 Repairing/Replacing Floor &/or Frame 44 12-27-2006 09:31 PM
Rear End Separation 76argosy26 Repairing/Replacing Floor &/or Frame 6 09-13-2004 09:32 PM
The dreaded rear end sag/separation Craig Repairing/Replacing Floor &/or Frame 5 04-23-2004 06:52 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
