Old 03-19-2018, 07:10 AM   #1
Silverback01's Avatar
1973 29' Ambassador
Knoxville , Tennessee
Outriggers
Why are the replacement solid outriggers notched!? When I lowered the shell after welding them on there they flexed more than I like as the shell rested on them. This seems to be due to the notch which takes away welding surface...am I missing something?
Silverback01 is offline   Reply With Quote
Old 03-19-2018, 08:38 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Any chance you can post a picture. I have the belly pan down and the wraps off. I have a couple of replacement solid outriggers under my trailer done by a previous owner.
I'm curious about a notch. I'd like to compare to the ones on my trailer.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 03-21-2018, 04:02 PM   #3
1973 29' Ambassador
Sure, as soon as I figure out how to resize images so I can load them here.
Old 03-21-2018, 08:02 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I use a program called "Image Resizer for Windows". It takes a 3.5mg photo and makes it a 200k photo. I thought AirForums did this automatically, maybe not. I resize as I'm on a data plan and don't want to spend the data uploading big files. I've been using it for a number of years.
http://www.bricelam.net/ImageResizer/
Here is a resized picture of my broken outrigger that we tried to weld back to strength. It was cracked. I think it will be okay now. We scabbed some material behind it not show in photo.
David
Name:	1801 Frame Weld Outrigger Repaired (Small).JPG
WBCCI #8607
VAC Region 11
Old 03-22-2018, 10:07 AM   #5
1973 29' Ambassador
Tryng to attach pic, let's see if it worked
Old 03-22-2018, 10:10 AM   #6
1973 29' Ambassador
Attached is a pic of the solid outrigger. Not near my camper, so had to take this one from the web. The notch I am referring to is the one in the top right corner
Old 03-22-2018, 12:15 PM   #7
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Outriggers
Some have suggested they are designed to break off/ buffer damage in an damage event. Personally, I made new ones out of 2x5 rectangular tubing and cut then to the proper profile. I welded mine completely-no notch. My reasoning is that if I have a collision that could rip one off I'd have a lot to repair anyway. Just weld the outriggers the way your comfortable with. The floor ties it all together so no worries if you leave the notch.
Don't overthink everything. You'll end up in quick sand and immobile.
I took everything one step further and placed a 1 1/2 inch perimeter band welded to the outside edge of the outriggers. I wanted to be able to remove the floor without taking the shell off. The point is: notch or notch welded will be fine
Matt
rugjenkins is offline   Reply With Quote
Old 03-22-2018, 06:59 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
A picture is worth a thousand words as they say. I don't know the reason for that notch. I will look at a solid replacement outrigger on my trailer next time I'm in the shop.
David
WBCCI #8607
VAC Region 11
Old 03-22-2018, 07:58 PM   #9
1973 29' Ambassador
Thanks for the program advice!
Old 03-22-2018, 08:09 PM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Notches look like a good place to run electric brake wiring through - as well as anything else needing to span wheel opening outside the ladder frame?
Andy once said there is no limit how many outriggers can be installed, there is no need to remove and replace in exactly the same spot, just 'bypass' the rusted, cracked or pretzel-bent ones by sistering in another alongside. Also - popped rivets can be from outrigger damage and it's willy-nilly where the loose outriggers transmit the motion to shear rivets.
I wish I'd photo documented what I found under the wraps on my '73, two outriggers twisted and mangled flat up to the floor, a solid unwelded and screwed in place with #12 sheetmetal screws.. and that was just on curbside.
Source for outriggers Happycampers Repairing/Replacing Floor &/or Frame 2 06-30-2007 07:25 PM
Outriggers [frame parts] boatdoc Repairing/Replacing Floor &/or Frame 4 09-21-2006 02:48 PM
Missing Outriggers!!- Full Monte??? fly2havefun Repairing/Replacing Floor &/or Frame 9 06-14-2006 12:38 PM
Outriggers?? ScrapIrony-2 Off Topic Forum 2 06-19-2004 11:50 AM
outriggers joaks Repairing/Replacing Floor &/or Frame 6 10-09-2003 02:30 PM
