Old 11-08-2008, 07:44 AM   #15
pauly g's Avatar
1960 22' Safari
Oceanside , California
Where do you find a friend that will live under your airstream like that? I hope you give him some good food. I agree with d'drummer about a double frame channel. Corosion would probably happen between the two pieces. Maybe you could "box" the channel in with rectangular flat plates around the weak areas, and shoot a coating in there from the ends to prevent corrosion.
pauly g is offline   Reply With Quote
Old 06-09-2009, 04:38 PM   #16
floridartist's Avatar
1973 29' Ambassador
Fort White , Florida
frame rot job done
Happy to say the frame rot job is finished, total cost $1,300.00 ,now for the first time in 6 months, early this morning I took The streamer off its jack stands, and backed the streamer up to my garage shop for the belly wrap job, being the tires are back on I have made a ramp which now gives me over 30" clearance to clawl around under the carrage, I picked up some roofing roll 4' x 10' at $ 25 bucks a sheet and the insulation is ready to go, as I have read in the forums, this might not be the best of all bests as for the belly wrap, but it will serve my personal purpose, also I have some short galvinized sheet metal screews with the rubber washer, how can that hurt,? and thats the way I plan to install my belly pan, soon I will have pictures, , thank you, John
floridartist is offline   Reply With Quote
Old 06-09-2009, 05:25 PM   #17
Kevin245's Avatar
Hey John,
Glad to hear you're getting closer to being back on the road again.
The use of galvanized screws may set you up for galvanic corrosion. The rubber washers will help insulate the faying surfaces, but if contact is made, your aluminum belly skins will become the sacrificial anode.
The Anodic Index (AI) for aluminum is anywhere from 0.75 to 0.95, and the AI for zinc is in the 1.2 to 1.25 range. In a potentially wet environment it is desirable to keep the AI differential to 0.15 or less to minimize this characteristic.
Regards,
Kevin
Regards,
Eleanor Roosevelt
Old 06-11-2009, 04:22 PM   #18
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I have a dumb question. Can new outriggers be welded on to the frame with the existing floor still in place? I would assume no, but thought I would ask.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-11-2009, 06:15 PM   #19
They sure can, but you must shield the wood best you can, and have some water standing by.
Some burning of the wood may take place, but you can paint that area after the outrigger welding is done. That will shield the burnt wood smell.
Street side rear outrigger davidz71 Wheel Wells 11 11-20-2013 10:16 PM
u-channel down against the outrigger? cosmos Repairing/Replacing Floor &/or Frame 17 01-15-2008 09:18 PM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 10:03 PM
Rot Dr. Mariner Repairing/Replacing Floor &/or Frame 5 04-15-2004 08:25 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
