Old 08-09-2004, 03:30 PM   #15
Images: 59
Originally Posted by biggerbadbrad
All I know is that poop flows downhill!
So you're a plumber then, not a pipefitter.
Old 08-12-2004, 04:47 PM   #16
blrpix's Avatar
Red face Al Capones vault...
Well almost as exciting as when Heraldo went in.
So I finally got under the floor panels and there was a whole lot of nothing...just insulation and frame..whcih is good I think, but it leaves me perplexed as to why this was done?
Here are some pix...if anything looks abnormal could someone point it out? The cross members are original correct?
Thanks.
ID:	8305   Click image for larger version
blrpix is offline   Reply With Quote
Old 08-12-2004, 05:11 PM   #17
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
My 65 Globetrotter did not have kraft paper backed insulations bats. And the bats were stapled to the floor AND they were between the frame and the plywood floor.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-12-2004, 05:47 PM   #18
blrpix's Avatar
Question
Bobby,
Does yours have the crossmembers that run up the middle, between the main frame pieces? This starts after the front section on mine, there no frame support/crossmwmebers under where the gaucho would be.
Matthew
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 03:43 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 09:09 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Securing the floor whistler Repairing/Replacing Floor &/or Frame 21 05-02-2004 06:55 AM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
