Old 11-04-2006, 04:50 PM   #15
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Your not cutting the pan out, all you need to do is drill out about 75 rivets.
It will come down, if its in good shape you can reuse it.
If not a 4X8 sheet is about $50
'77 Sovereign Intl 31' CB
Old 11-04-2006, 05:05 PM   #16
tbrom's Avatar
1965 28' Ambassador
NewCastle , Pennsylvania
I don't think I'll reuse the old pan. I would rather use new material if it's feasible. Would you remove more of the floor than what is rotted? I am under the impression that most of my welding can be done from underneath.
Tbrom
tbrom is offline   Reply With Quote
Old 11-04-2006, 05:30 PM   #17
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Once the pan is down you can also inspect most of the plywood from the bottom.
Mine looked great except for two spots, one I didn't see from the top or inside.
I would only remove what is bad.
Old 11-06-2006, 07:13 PM   #18
1978 31' Sovereign
Moncton , New Brunswick
Lipets,
Thanks for the info and picture on your frame repair. Did you have to do any outriggers. Also did you insulate below the floor and in between the belly pan or leave it open?
Toga
toga is offline   Reply With Quote
Old 11-06-2006, 07:29 PM   #19
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Outriggers were ok, a few bolts were missing, don't know why?
No insulation in the belly, I am putting it inside on the floor, with Pergo on top.
If you want to put it in the belly or on the floor do NOT use the pink stuff, only use the foil bubble it will not absorb moisture and it has an R-14 rating.
Old 11-07-2006, 06:58 AM   #20
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
bubble insulation
We just came home with our AS two days ago. The very first thing my husband did was start taking down the belly since it had mice underneath in the insulation. I can really see the validity of Bob's bubble insulation over the standard; all the insulation was a soggy matted mess filled with mouse waste. UGH.
Luckily the floors appear to be ok in general and not rotted. However we do need to replace a couple of outriggers. Can someone give me the link to out-door-mart?
I would think that the bubble in addition to being drier would be less likely to get critters in since it wouldn't make good nesting. (?) I couldn't quickly find the link in the forum as to where to best buy the bubble insulation, but know that it can be bought at Farmtek.
I don't know how the prices compare but there is the link: http://www.farmtek.com/webapp/wcs/st...egoryIds=11210
wannaroam is offline   Reply With Quote
Old 11-07-2006, 08:52 AM   #21
tbrom's Avatar
1965 28' Ambassador
Wannaroam,
Where is Harmony PA?I believe you are just down the road.
Tbrom
Old 11-07-2006, 11:40 AM   #22
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Insulation
I was recommended this product:
http://www.prodexsa.com/
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 11-07-2006, 12:56 PM   #23
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I bought mine from these guys,
good to deal with, but no phone help, but you really don't need any.
Old 11-08-2006, 06:06 AM   #24
wannaroam's Avatar
Images: 36
tbrom
Harmony is right beside Zelienople.
On the outrigger replacement, would it better to use a stick welder or a small 100 amp Mig welder?
Also how would you bolt it if you aren't taking the flooring above out?
Old 11-08-2006, 08:11 AM   #25
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Don't follow that part of the question
Old 11-08-2006, 08:48 AM   #26
wannaroam's Avatar
Images: 36
Are the outriggers bolted on the top side into the floor?
Old 11-08-2006, 09:39 AM   #27
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Yes there are two bolts one at the outside edge thru the C channel and another about 6-8" inboard.
Old 11-08-2006, 10:59 AM   #28
wannaroam's Avatar
Images: 36
Ok, so if you aren't taking the plywood floor out above the outrigger you are replacing, is there a way to bolt it?
Service policy opinions needed :) Kistler Our Community 8 07-20-2003 09:16 PM
need quick opinions on tires... vbob Airstream Motorhome Forums 14 03-01-2003 07:22 AM
Need Slide-Out Opinions! rickdesign Our Community 10 02-14-2003 11:29 AM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
Another What is it? airstreamcaravel Exterior Restoration Forum 15 09-12-2002 10:27 AM
