Originally Posted by reinergirl
Hmmmm, I'm no expert but I'm going to remove all of my interior skins and belly pan and then...gasp... take the trailer back on the road to Colin Hyde's for the floor replacement. It certainly isn't going to be level in the meantime! I think you really want it level and perfect when you remove the shell and replace the shell back on but otherwise it's okay.
Im doing the floor replacement with full shell on and have to date put in 4 out of 7 sheets by removing the bottom Inside skin, pan in butt this way.
When I peaked under the middle panel it smelled and I could see where mice have made tunnels. so im gutting all panels to replace with new insulation after im done checking frame, coating with POR and replacing the floor.
I would think since its not a shell off removal, I wouldnt have an issue with it fully level every where but just front to back is fine.
