Old 10-29-2016, 10:16 AM   #1
SkatiePower's Avatar
beecher , Illinois
One broken outrigger...
We have one broken outrigger on our 34' Airstream. The rest seem pretty solid. I know a boilermaker who could fix it, but I would have to buy a welder because he doesn't own one. Is it worth the money to fix one outrigger?
I was also thinking about trying to find a way to bolt a support to it. Possibly using a piece of angle iron and bolting it to the top of the outrigger and then to the bottom of the frame. Has anyone done this?
Scott and Kate
Husband and wife working towards full-timing with our beagle.
IG: mossandcedar
SkatiePower is offline   Reply With Quote
Old 10-29-2016, 10:32 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I think anyone who does welding could do a repair pretty simply. Personally, if this is the only outrigger, I would have no problem cleaning it up, rustproofing it and bolting on some reinforcement.
Old 10-29-2016, 10:39 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Considering the solid one just forward of it that is not much more than a support for the skirt.
As noted you could clean it up and coat it and bridge the gag with a piece of sheet metal to support the skirt.
One of mine was eaten out just behind the wheel well and I covered it with sheet metal to keep rain spray from wetting the underside of the floor.
2004 Excursion 4x4
Old 10-29-2016, 10:45 AM   #4
beecher , Illinois
Thanks for the replies. Looks like I will just be adding a support. That is the response I was hoping for
IG: mossandcedar
Old 10-29-2016, 05:22 PM   #5
beecher , Illinois
Here is how I ended up fixing it. The aluminum will be riveted to the original outrigger once I find my riveter. I wouldn't be surprised if it were stronger now with than angle iron than the original was.
IG: mossandcedar
Old 10-29-2016, 06:17 PM   #6
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Are we not concerned about galvanic corrosion?
Just curious.
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 10-29-2016, 08:01 PM   #7
beecher , Illinois
Just curious.
Bruce
I considered that, but figured since the belly pan was riveted directly to the frame and other than the rust on the frame, it looked fine, that it would be okay. Either way there will be aluminum/steel contact, be it from my "aluminum outrigger" to the frame or from the steel outrigger to the belly pan, unless there is something I'm missing.
I can still change it out if it may be an issue.
Edit: Thinking about it and maybe I should remove it for now until I get the POR-15 on the frame. The angle iron came painted.
IG: mossandcedar
Old 10-29-2016, 11:43 PM   #8
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
You could bolt some steel on there and wouldn't have any worries. Personally go buy a cheap harbor freight flux core welder for a $100 and weld a patch piece. I re-engineered my whole frame and taught myself how to weld. It's easy with a flux core welder. Don't let metal work intimidate you! If you can rivet you can weld! Plus you get a new toy😁👍.
Matt
rugjenkins is offline   Reply With Quote
Street side rear outrigger davidz71 Wheel Wells 11 11-20-2013 11:16 PM
outrigger rot floridartist Repairing/Replacing Floor &/or Frame 18 06-11-2009 07:15 PM
Framing with 5" channel - outrigger source JoePfznik Repairing/Replacing Floor &/or Frame 3 02-14-2009 04:56 AM
u-channel down against the outrigger? cosmos Repairing/Replacing Floor &/or Frame 17 01-15-2008 10:18 PM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 11:03 PM
