Old 08-14-2008, 08:24 PM   #1
jkrauk's Avatar
1978 23' Safari
1956 22' Flying Cloud
Orlando , Florida
Ol' hunt camp needs some frame reinforcing
I am starting with the foundation on this project and need to get the frame up to par. I took the belly pan and bananas off. The '78 already has many holes in the frame and a few outriggers completely gone. What is the bet way to reinforce these holes in the frame? I have my welder ready, we are just contemplating the easiest and cheapest way to weld on some fresh metal. What should the sistered piece look like?
Thanks, John.
jkrauk is offline   Reply With Quote
Old 08-14-2008, 09:11 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That looks kinda bad. I would think about maybe cutting it out and welding a new piece in... It will continue to rust unless you sand blast it and treat it....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-15-2008, 04:57 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
An alternative is to sister in a piece of C channel on the rusted frame. After the C channel is reinforced, you can put por-15 and paint on it to prevent further decay.
Old 08-15-2008, 06:40 AM   #4
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
We just had our welder fix the tongue on our '56 Overlander last night. He had everything he needed in his trailer and came out and cleaned up the tongue then reenforced the two breaks. Here are some photos.
If you want more photos - visit our website www.ClassicAluminumTrailers.com and click on '56 Overlander under "Our Trailers"
ID:	65734   Click image for larger version
ID:	65736   Click image for larger version
April & Andy Hershberger
3streams is offline   Reply With Quote
1978 Safari restoration "the ol' hunt camp" jkrauk 1974 - 1979 Safari 10 11-26-2008 04:58 AM
Howdy! From An Ol' Ag! Dr. E Member Introductions 8 07-05-2006 09:24 PM
Rear end reinforcing on a 62 Overlander Silverfly 1960 - 1964 Overlander 2 06-22-2004 08:21 PM
Reinforcing Tambour Doors Navigator Cabinets, Counter Tops & Furnishings 1 03-04-2004 11:28 PM
