Old 02-29-2012, 06:09 PM   #15
1965 22' Safari
East Islip , New York
There was a fairly lengthy thread on Nyloboard a while back that kept popping up again every few months.
Initially there was a big concern since many plastics have a high expansion rate, and at the time Nyloboard did not publish the data on this. Eventually they DID publish it, and it actually seems to have very little expansion at all... less than most woods actually, and is a better match to steel and aluminum from an expansion standpoint than the original plywood floor.
-Hans
HHaase is offline   Reply With Quote
Old 02-29-2012, 07:21 PM   #16
Lothlorian's Avatar
Loganville , Georgia
I was doing my first ever restoration so I had to learn as I went along with it. I decided from the beginning I was not going to do a full monte and I was not going to gut the trailer.
I took the bathroom out and drilled holes through the cross member (It already had holes for my bit to go through. I snapped a line and cut the floor in the middle of the cross member. So I would have room for a cut piece to fit. I then took a cross piece of garage door track and welded it on the cross member of the trailer for extra room for the new floor piece to sit on. I bolted the new Nyloboard floor on that piece. I had a piece of thin flat steel I was doing anything with and laid / attached to the black tank box right where the pieced of Nyloboard was going to sit. There was not going to be any sag plus keep the two cut pieces together. Honestly everything has worked for years and no complaints.
I think it came out great not knowing what I was doing. Check out these few links which shows the nyloboard and how I did it. Hey if it messes up I will just fix it.
you can see on the last link I have a wood but plate. I changed that out with the 4' wide sheet of steel. I made that decision after I realized the black tank would not fit.
http://www.airforums.com/forums/f36/...ion-38204.html
http://www.airforums.com/forums/f36/...n-38204-3.html
http://www.airforums.com/forums/f36/...n-38204-4.html
http://www.airforums.com/forums/f36/...n-38204-5.html
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-29-2012, 07:48 PM   #17
r carl's Avatar
Lin , Ne
Any info on the flamability of nyloboard?
Old 02-29-2012, 08:31 PM   #18
1965 22' Safari
Here's the current datasheet for it. Oh, and it's now called nylosheet
http://www.nyloboard.com/Portals/20/...%205-11%20.pdf
ASTM E84: Class C for the G2 nylosheet
ATSM E84: Class B Smoke for the G4 nylosheet.
Not that I have the slightest idea what that means.
-Hans
Old 03-01-2012, 03:06 PM   #19
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
Nyloboard alternatives
Originally Posted by wasagachris View Post
I have several trailers to restore and am considering using this product as an alternative to plywood. For my first trailer I used MGP and a very expensive coating to seal it. I think that the costs were similar to using Nyloboard.
So if you have used this product and have any comments regarding it please post here so that I and other furure restoers can find the info quickly.
Heya Chris, you have an interesting alternative available that is manufactured pretty close to you, in Mississauga, Polyboard. They recycle plastics from industry (probably cutoffs from moulded door and dash panels, think Oshawa), comes in grey and white, plus it is 'green'. I do believe that is what I will use when we do the floor on Bubbles. We may have to install a couple of angle iron cross member supports but that will be a small price to pay for NO ROT.
This is the link: Polyboard | Renew Resources
I will use the grey and if it looks ok I may even forego putting anything on the floor except for a few rugs, or maybe some vinyl plank.
Looks like you are enjoy your trip you traitor, have fun with your Mom. It is truly miserable here in Ottawa today.
Hoist one for all of us in the Great White North,
Cheers
Leonie
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 03-01-2012, 03:15 PM   #20
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Originally Posted by perryg114 View Post
How much scrap do you have left? If you had a 4 ft section you could do some flexture tests for us against plywood. Take an equal thickness section of wood and Nyloboard and suspend it between two saw horses and sit a cinder block in the center of both of them and see how much sag they have relative to each other. I am thinking something 4 ft long and 1 ft wide.
Perry
I don't have scraps that size but maybe others that have used it in the past do. If I recall correctly, one Forum member was doing the full floor replacement w/ nyloboard
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 03-01-2012, 03:26 PM   #21
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Cheers
Leonie
I've looked at their brochure and based on that info I did not see the polyboard being used as a main building component as nyloboard is sometimes used in 3" or more thickness. This would be another place for a strength test between products. I'm 6'6" and 240 lbs and my nyloboard flexed less than a plywood sheet the same size/ thickness - very rigid stuff.
Air Cid
Reese WD Hitch
Old 03-01-2012, 03:30 PM   #22
x
XXXX , XXXX
Leonie I just did a little research on polyboard. IMO it's not a viable alternative to Nyloboard. First it's 40% heavier than wood and secondly it has quite a large expansion rate. 1/4" over a 4x8 sheet. they recommend leavinga 1/4" gap between sheets and to expand the mounting holes to allow for this expansion/contraction.
Polyboard
wasagachris is offline   Reply With Quote
Old 04-25-2012, 12:17 PM   #23
USN Avionics Tech QA Insp
LarryGlover's Avatar
Morristown (Gatlinburg, Pigeon Forge area) , Tennessee
Images: 8
Exclamation NYLOBOARD Installation or repair???
A lot of people are asking quesitons here, but noone has of yet asked the big questions that come to my mind. As a former Naval Aviation type, I have the following concerns:
  1. Is there a major cost difference between nyloboard and wood?
  2. Are there any special tools or procedures required for installation? Any special types of epoxies, sealants, caulks, etc.?
  3. Can Nyloboard be repaired if cracked or damaged, and if so; what is the procedure?
I have contacted the MFG directly to see if my questions can be answered. I will post the information or a link to any informational sites that are supplied by the MFG.
LarryGlover is offline   Reply With Quote
Old 04-25-2012, 05:15 PM   #24
1973 25' Tradewind
Augusta , Georgia
I called Nyloboard last week to get pricing. The minimum factory direct order is 20 sheets at $175 per sheet for 3/4" material. If you want to order less you go though a distributor, Piedmont Plastics. I've called Piedmont Plastics multiple times, both local and toll free and nobody answers the phone.
I called Nyloboard back and informed them that I live about 100 miles away and would be interested in 6 sheets or one sheet 22 feet long. I was told I would have to go through the distributor, Piedmont Plastics, and could pick up at factory. I then asked about blems/out of square sheets. The girl was going to check and call back. I left a message with her on Monday. May try back later this week.
I'm still working on holding tank installation, as soon as I get this completed looks like the floor will be 3/4" marine grade available locally at $75 per sheet.
I really like the Nyloboard product and NO ROT is very appealing, a solid piece floor would be REAL SEXY, but not at 2.3X the prices and a non-supportive distributor network.
If anybody has had better luck in 2012 I would love to hear your approach.
DGJackson is offline   Reply With Quote
Old 04-25-2012, 05:49 PM   #25
1981 31' Excella II
New Market , Alabama
Maybe you should contact the Nyloboard marketing person and tell them that their dealer networks sucks and that they are loosing business. There are alot of products out there but they are not main stream yet and that makes them a semi black market item to Joe Airstream who wants a few sheets. You mean you want our super special semi secret Nylo board. Shus where did you here about it. You are not supposed to know about it. We will sell you some at a price and a free tube of lubricant of you choice. Aluminum composite is another option and expensive in small quanities. It is hard to beat wood eventhough it has issues.
Perry
Old 05-09-2012, 01:21 PM   #26
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Here are some stats I pulled off the web. Very intresting, but I don't know if it's worth the cost..
NyloSheet Specifications
Specifications:
NyloSheet is available in sheet form in a range of thicknesses, sizes and strengths to suit a wide variety of applications.
  • Standard sheet size is 4’ x 8’
  • Custom sheet sizes up to 24 feet long.
Test Results:
Mold Resistance ASTM D 3274: 10 ratingFungal ResistanceASTM D 1413: No decayTermite ResistanceAWPA E1-97: 10 ratingG4 Coefficient of Thermal Expansion ASTM D696: 0.64 x 10-5 in/in/F
(best of all composites)G2 Coefficient of Thermal ExpansionASTM D696: 1.64 x 10-5 in/in/FG1 Coefficient of Thermal ExpansionASTM D696: 3.3 x 10-5 in/in/FG4 Flame SpreadASTM E84: Class BG2 Flame SpreadASTM E84: Class CG4 Screw Retention 1/2" 35PCFASTM D1037: 512lbfG4 Screw Retention 1" 35PCFASTM D1037: 760 lbfG2 Screw Retention 1/2" 40 PCFASTM D1037: 576 lbfG2 Screw Retention 1" 40 PCFASTM D1037: 1036 lbfG1 Screw Retention 1/2" 40 PCFASTM D1037: 632 lbfG1 Screw Retention 3/4" 40 PCFASTM D1037: 886 lbfG4 Flexural MOE 1/2" 35PCFASTM D790: 464k psiG2 Flexural MOE 1/2" 40 PCFASTM D790: 165k psi
Silverflames is offline   Reply With Quote
Old 05-09-2012, 01:33 PM   #27
1981 31' Excella II
Now we need a chart comparing the same properties to wood.
Perry
Old 05-09-2012, 02:49 PM   #28
salzburg , salzburg
well from what i see you guys have it good, i will spend upwards of 500 for my 25' tradewind wood floor! so $75 a sheet for me seems quite reasonable but i will say the floor, although totally wrecked had been in my trailer for 40 years i have no problem putting wood in again as i am already 40 and i don't really care who does this next!! as it will definately not be me, saying that i have fond plyboard which they use on truck flooring which i am thinking has some pretty nsaty chemicals in it to stop it rotting which is where i'm going!
mrgreen is offline   Reply With Quote
CAT scale results .. your thoughts RTurnConn Hitches, Couplers & Balls 20 07-10-2017 07:34 AM
First test towing AIR-Quarius On The Road... 10 12-21-2011 10:57 AM
How to test fridge circuit board ? Davis Refrigerators 9 10-29-2011 04:25 PM
Test -- don't delete Zeppelinium Forum Admin, News and Member Account Info 12 10-23-2011 09:36 AM
