Old 05-21-2008, 02:24 PM   #85
aka Seattlebound
IndyAnne's Avatar
Profile:  1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Malcolm, thanks very much for your reply on the shears. I've sent a PM to say, basically, that I am leaning toward the air shears because the electric one is so heavy. I think if the compressor will handle the air flow, the fatigue factor will be less than with electric. I'll follow up more on the shears on my renovation thread.
Anne
Originally Posted by malconium
Anne,
I live in Portland, Oregon but I telecommute to a company in Tempe, AZ. On one of the last trips that I made to Phoenix I spent both directions sketching up all sorts of details for how I am intending to put my Airstream back together.
I don't think you will have any problems with shears with your compressor but I would like to hear how it goes. I still want to buy a pair of shears and I have been debating whether to buy electric ones or air powered. Have you bought your shears yet? Where did you get yours? I think that pretty much any tool that does not use a continuous large volume flow of air will work just fine.
If you have not yet bought a rivet gun I can recommend one like what I bought at Harbor Freight.
Harbor Freight Tools - Quality Tools at the Lowest Prices
Do you have a local Harbor Freight store? If you do you might want to check the online price for anything you buy and call the store before you go to see if the item is in stock. If the store price happens to be higher you can take in the online print out and they will typically honor the online price.
Malcolm
Anne
Indianapolis, IN
IndyAnne is offline   Reply With Quote
Old 05-21-2008, 02:29 PM   #86
cameront120's Avatar
Profile:  1972 25' Tradewind
Try looking at air-powered nibblers. They don't seem to deform the sheet metal like some sheers can.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 05-21-2008, 02:42 PM   #87
Profile:  1973 31' Sovereign
Portland , Oregon
Shears vs. Nibblers...
Out of curiosity I took a look at Harbor Freight shears and nibblers. The shears are rated at 4 CFM of air while the nibblers are rated at a whopping 17.5 CFM of air. I would guess this is because the nibbler runs continuously more like a saw would while the shear runs on a more part time basis. For my compressor I know that I would have to stick with the shears just because of the air flow requirement.
Interestingly there may be some printing issues in the Harbor Freight catalog. The pistol grip shears are the ones that are rated at 4 CFM while the straight shears are rated at 16 CFM. So which one is right?
Malcolm
malconium is offline   Reply With Quote
Old 05-21-2008, 04:20 PM   #88
Ambie '64's Avatar
Profile:  1964 28' Ambassador
Phoenix , Arizona
Nyloboard and compressors...I'm ready! Uwe, let me know how that sample holds up under your scrutiny.
Ambie '64 is offline   Reply With Quote
Old 05-21-2008, 04:33 PM   #89
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Well, funny you asked...I just got a quote from them, looks like about $ 693 for one kind, and $639 for another kind of 3/4 Nyloboard. The size requested was 8ftX19ft for a Flying Cloud. I don't even know if that would be the right size, I eyeballed it for the quote only.
$ 4.56 per square foot.
Depending on the freight charge, this might just work. But with fuel being so high, I am afraid that the freight charge might blow the deal out of the water.
I am supposed to get a freight quote next week.
Uwe
www.area63productions.com
Old 05-22-2008, 04:44 AM   #90
Profile:  1973 27' Overlander
Loganville , Georgia
Uwe:
Nyloboard will send you samples for free so you can compare.
SIU Bound
Lothlorian is offline   Reply With Quote
Old 05-30-2008, 11:56 AM   #91
Area 63 Productions
Commercial Vendor
Orange , California
Send a message via Skype™ to Area63
I received the samples, and they look very nice, feel nice and will be cut and drilled into tody to see how the material compares to Marine ply.
I received a bare sample, and one with fiberglass surfaces.
Uwe
Area63 is offline   Reply With Quote
Old 05-30-2008, 12:03 PM   #92
Area 63 Productions
Commercial Vendor
Orange , California
I got the freight quote.....
Hi Uwe,
This is the information I just received from shipping and receiving. I know you are trying to use one piece and that will be awesome! Another alternative would be to use 4x8 sheets. Thanks, ~Kimberly
This board 3/4”x8’x19’ will weigh about 775 lbs and will be hard to handle without a pallet, freight companies are saying it needs to go on a flat bed
Old Dominion pup truck quote $3100.06
Trans – National quote for flat bed $2500.00
That's for the one piece.
For a pallet with 5ea. 3/4 x 4x8 is the following:
Uwe,
Much better!
Old Dominion quote for one pallet weighing 475 lbs
Quote $265.44
So, while the freight for a pallet of sheets is surprisingly reasonable, the one piece floor shipping is completely out of the question. Heck, I could go from CA to GA and get it for that price...
Uwe
Old 05-30-2008, 01:03 PM   #93
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
Waukesha , Wisconsin
This board 3/4”x8’x19’ will weigh about 775 lbs...
For a pallet with 5ea. 3/4 x 4x8... weighing 475 lbs
Something is wrong with Kimberly's math if 19LF weighs 300lbs more than 20LF.
I would think you could do just as well with 4X8 sheets since you will have the side drops to use a splines at the joints. Just use the fiberglass faced product and epoxy the lap joints together. This would provide a stronger and stiffer floor than the single sheet.
I can't wait to hear the results of the "destructive" testing.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 05-30-2008, 03:46 PM   #94
Profile:  , Minnesota
Images: 59
I'd double check with Old Dominion on the freight quote. It will take two pallet spaces rather than just one pallet.
