Old 03-04-2011, 12:30 PM   #1
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Now I can see what I've got to deal with!
Here's where I'm at on the project:
1. Bath completely removed.
2. Plumbing completely removed from bath and rear compartment.
3. Univolt removed.
4. Battery compartment removed.
5. Water heater removed.
6. Belly removed from axle to rear banana.
7. Black and Gray water tanks removed.
I finally got my first real look at the frame members.
Looks like I'm going to be doing a "Shell Off" job.
ID:	123603   Click image for larger version
ID:	123605   Click image for larger version
2Rhinos is offline   Reply With Quote
Old 03-04-2011, 01:29 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Honestly, it doesn't look that bad. Clean up the frame and use POR-15, replace the wood and you will be good to go. If you need to "sister" the rear cross member or even replace it that can be done without removing the shell. The rear cross member was completely gone on my TW, I welded in a piece of angle iron. Of course a lot depends on the rest of the frame, but do not underestimate the time factor if you do a complete shell off.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
Old 03-05-2011, 10:04 AM   #3
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
More photos
ID:	123701   Click image for larger version
Old 03-05-2011, 10:12 AM   #4
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Thanks for the input.
I will know more as I dig in deeper, but I hope I don't have to do a "shell off".
First impression is that the frame is in fair condition. Fortunately, it's only had 2 owners and I had the opportunity to talk to the previous owner regarding its history.
Everything is original except the front sofa/sleeper.
Old 03-05-2011, 11:12 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did a shell -on floor replacement, and used Rustoleum instead of POR15 due to cost. It is possible to do shell-on and not have to cut your flooring pieces in half as some have done. We detailed some of it in our thread "Little Girl Refurb". Others have done it too. Shell off has some advantages too, I think. We just did not have the equipment to do shell-off very easily. There are lots of threads to look at for ideas in how to do different things. Do some heavy duty reading before you decide what is best for your situation. Lots of good info in these Threads!
Kay
P.S. She's a good looking girl!
The old girl needs new shoes.... Trex 1970 - 1973 Sovereign 1160 03-04-2017 10:39 AM
2008 International 75th Anniversary - 25ft Frank&Mike 2006 - 2010 International 34 03-31-2011 04:41 PM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
Carrier 13,500 ac unit for a 66 safari 386kustoms Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-12-2011 08:24 PM
Amending the Amendments. boatdoc WBCCI Forum 14 02-10-2011 12:02 PM
