Hi everyone! I recently purchased a 1975 Argosy 20 foot trailer. I plan to partially gut it and renovate. My first step is replacing a window (that's a different post) and second is the flooring. I do not want to do a shell off renovation. Has anyone replaced the floor on their Argosy and has documented their steps. I am completely inexperienced here so any guidance is much appreciated! Also, can I replace the floor without a full plan for the plumbing/electrical? Or are there lots of things that need to be planned out before the floor is replaced? Thanks!
Howdy! The goal is to find a way to remove the existing wood and replace between frame and the c-channel the skins and ribs attach to. Ideally removing inner skin in area of replacement should allow loosening of channel to frame fasteners. That will help wood slip out... replacing will probably need to be done in pieces then double the joints.
Peace and Blessings..
Channing
WBCCI# 30676
Thanks! What type of wood is usually used for the floor? Just plywood at same the same thickness as the existing?
Your plumbing is above the floor with the exception of the shower drain, you can see it once you have the belly pan off. If your doing a shell on replacement your electric shouldn't require much of plan either. You will have to move the converter around when you start on the back but other wise should be smooth sailing.
One thing you may want to consider is just replacing the damaged area. I replaced only the area below the front couch and pieced in the new plywood ensuring all seams were over a solid frame piece and tucked into the channel. I then covered the entire area wall to wall with a solid sheet. It supported my weight without any give, then I reinstalled the front couch and water tank.
