Old 09-14-2011, 08:59 PM   #1
2005 28' Safari S/O
Powell Butte , Oregon
New outriggers?
I have a 68 International 31' stripped on the inside because of a severely rotted floor and rusted frame. I can allready see that I will have to replace a number of the outriggers on the frame. Is there a good source for these frame parts or am I going to have to make them?
Also is it better to lift the shell off from the from the top by using a beam and straps up to a Caterpillar Reachout or from the bottom with jacks?
Also how much will a 31' that is stripped of everinging including the inside skin weigh?
sawdawg1 is offline   Reply With Quote
Old 09-15-2011, 05:18 AM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Out of Doors mart has the outriggers. Maybe Inland RV.
It is said that it is easier to lift the shell from the top.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 09-15-2011, 06:56 AM   #3
If your fasten some 2 X 4's on to the main bows, you can lift the shell off the floor.
Then have some longer 2 X 4's or 2 X 6's, placing them under the shell and on top of some saw horses.
For a 31 foot trailer, you should use 4 saw horses on each side.
Once the shell is raised high enough, simply pull the chassis out from under the shell.
Old 09-15-2011, 03:46 PM   #4
Tool Hoarder
West , California
Got my outriggers from Inland Rv they worked out great!
marzboy is offline   Reply With Quote
The Aluminum Falcon Darkspeed 1970 - 1973 Sovereign 276 07-15-2016 01:38 PM
1973 Sovereign: 'Bauxter's Big Adventure' Bauxter 1970 - 1973 Sovereign 115 03-16-2015 12:56 PM
The Fun Begins wasagachris 1973-1974 Excella 500 684 09-26-2014 07:16 AM
1961 Space Liner douglasbury Airstream Trailer Forums 22 11-29-2012 08:21 PM
Frame through side by wheel well Darrengj 1966 - 1968 Safari 5 08-21-2011 10:04 PM
