Old 04-08-2015, 12:19 AM   #1
1979 23' Safari
Wayland , New York
New hold down bolts
Thought I'd throw this out there to see what others thought or if anyone had bullets to shoot through my idea. It's already done but still at a stage I can undo it fairly easily.
When I removed the shell I obviously had to take out the old hold down bolts. Like most I'm sure found they were badly corroded, many with enough corroded that there was often a significant thickness (strength) of the bolts gone. Original bolts were 1/4 inch. Looking at them as they came out my engineering brain noted that most of the corrosion was on the bolts where it passed through the wood, and were often in better condition above and below that section. I surmised that the wood which will always retain some moisture accelerated the corrosion where the bolts were encased in the wood. Many of the bolts had about half their thickness corroded away.
When I put this back together I don't want to worry about getting to the bolts for a good 30 years again, so solution?
I put my engineering degree to work and decided to replace all the hold down bolts with stainless steel bolts. since the stainless steel is slightly weaker than steel I increased the size of the bolts by drilling them out slightly larger to replace the hold down bolts with 5/16" vs the original 1/4". It wasn't just a what's the next size up, I pulled out the old calculations for the root diameter of the bolts to determine the effective diameter of the bolts and used yield/tensile strength of the stainless (65/100 ksi). Compared this with regular steel Grade 2 (57/74 ksi) and grade 5 bolts (92/120 ksi). Went to work and calculated the bolt strengths. I also got way into the weeds and calculated what the tear through would be for the bolt to tear itself through the steel of the outrigger. Lots of number crunching.
With the size increase and stainless steel they came out stronger than grade 2 grade 5 or grade 8 bolts in 1/4 inch.
Torqued the bolts to 130 in-lb with nylock stainless nuts and stainless washers on both sides.
Overall it cost a little more but I think it will be well worth the small difference.
Old 04-08-2015, 05:55 AM   #2
judflor's Avatar
1977 31' Sovereign
Stuart , Florida
Sounds good to me. I also am an engineer. You can get some high strength 1/4-20 stainless steel bolts - 17-4 SST 135,000 psi min tensile strength, A286 SST 130,000 psi min tensile strength and Bumax 88 SST 116,000 min tensile strength (see McMaster-Carr catalog); not as high as Grade 8 steel bolts (150,000 psi min tensile) but still plenty strong. I don't know what what grade bolts were originally used Airstreams but I bet you these stainless bolts would do the trick. I am thinking of replacing my corroded steel bolts with stainless steel bolts.
judflor is offline   Reply With Quote
Old 04-08-2015, 06:53 AM   #3
Heath , Texas
Thanks for this info on strength. I'm a big fan of SS despite the cost.
sailormom is offline   Reply With Quote
Old 04-08-2015, 07:08 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Agree. Permanent fix. I got lucky when I pulled up my flooring and found original bolts in very good condition despite being 61 years old. AZ weather probably helped that.
BambiTex is offline   Reply With Quote
Old 04-08-2015, 07:14 AM   #5
1981 31' Excella II
New Market , Alabama
I used stainless bolts on everything and I put 1x1 angle iron stiffeners on top of the C-channel to eliminate pull through and reduce point loads. The factory really botched the rear of my trailer and some of the bolts were at the very edge of the C-channel which weakens it considerably. The bolts that were used originally were pretty weak carriage bolts. I doubt you could go wrong with even cheap 18-8 stainless bolts.
Perry
Old 04-08-2015, 08:28 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
modern solution
If Wally would have had this available he would have used it. New deck screws are self tapping and strong. They are designed and made for flooring (deck) applications. No need to overthink the old carriage bolt replacement. (only my opinion.) http://www.grainger.com/product/SPAX-Deck-Screw-6PU93?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/6PU82_AS01?$smthumb$
Old 04-08-2015, 10:21 AM   #7
1981 31' Excella II
Most of those deck screws won't thread through metal. In fact, most of the screws designed for sheet metal won't thread through steel even with a pilot hole. I found some stainless sheet metal screws that were hardened and they work well for holding on belly skins etc but they have a hex head that is not flat. Deck screws work fine for wood to wood connections.
Perry
Old 04-08-2015, 10:20 PM   #8
1979 23' Safari
Wayland , New York
Thanks all, gives me a little more confidence that others have gone this route as well. I tend to overthink things sometimes. Well a lot of times. Try to think and plan everything down to the nitnoid detail taking in as many possibilities and options and come up with what will work best. Beat into me by the military, and always want to do things "right", not half a'd like a lot of things in the AS's seem to have been done. A "little" more thought and effort can go a very long way. Still seems true in the new AS's.
Brainstorming how to redesign the forced air to the tanks situation, and replacing the old fresh water gravity fill. Definitely didn't like how either was done in the first place. Been brainstorming all winter think I'm starting to finalize those. Probably post those ideas later.
Old 04-09-2015, 06:07 AM   #9
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Screws
Perry
I agree deck screws are best for wood not metal. I have, however, used stainless steel sheet metal screws to attach a new belly pan with good success. Drilling the right size pilot hole in the steel frame is the key.
Old 04-09-2015, 06:45 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I like the approach with the thru bolt and nylock in stainless. I replaced many over the years with this upgrade where I could improve bolt strength without damaging surrounding material. If you hold and don't crush the wood, that should hold the shell nicely.
I never used the swap where there was electricity passing. Not for grounds or interconnected parts where electrolysis can increase.
I also like the idea of spreader plates like the angle iron. But I might have tried aluminum instead.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-09-2015, 06:57 AM   #11
1981 31' Excella II
I coated the steel with POR15 to insulate and protect it. I did this on the fly and already had the 1x1 angle. You can also coat aluminum with POR15.
Perry
Old 04-22-2015, 07:07 AM   #12
1975 31' Sovereign
Davin , West Virginia
Since I didn't have access to under the frame/hold down plate for through bolts, this is what I used. Hardware man said it was grade 5. Also stepped up to 3/8 and added several extra bolts. They tapped the steel nicely and tightened up great.Click image for larger version
Name:	ImageUploadedByAirstream Forums1429708034.666792.jpg
Hillbilly75 is offline   Reply With Quote
Old 04-22-2015, 07:55 AM   #13
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I just got back to this...Deck screws are made for self tapping metal applications. Thats why they are used.
Old 04-22-2015, 09:50 AM   #14
1981 31' Excella II
You need to have through bolts on the hold down plate and on the corners where the larger bolts go into the frame. Sheet metal screws won't cut it for shell to frame connections. All those will do is hold the floor to the c-channel. Remove lower skins to do it right. No free rides or short cuts here.
Perry
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Hold down plate, Panel replacement - pic heavy! crispyboy Ribs, Skins & Rivets 13 05-13-2013 09:41 AM
Rear hold-down plate necessity? vhord Repairing/Replacing Floor &/or Frame 15 02-16-2009 01:44 PM
Black rubber T-handle hold-down, latch iowaroots Commercial Listings 0 09-10-2004 08:33 AM
Hold down for Rock Guard uwe Rock Guards, Segment & Window Protectors 5 04-24-2003 05:01 PM
