Old 08-07-2008, 04:22 PM   #1
Liz
1968 30' Sovereign
Newnan , Georgia
New flooring
Hi, we are restoring a 1967 Sovereign. It has come my task to fiqure out what flooring I want to put down. I have seen some with the laminate floating floor. Any info about how it holds up in something that while on the road, moves. I don't want to put carpet down. I have four dogs. I want something that will be easy to clean. Also what about a non glue sheet vinyl.
LIZ
liz1300s is offline   Reply With Quote
Old 08-15-2008, 09:52 AM   #2
1994 30' Excella
1973 25' Tradewind
wilmington , North Carolina
Flooring
Liz, I am in the same decision making mode on my 94 excella, the carpet is in bad shape, holds odor, dirt etc. I have a few wet spots. Anyway I have it almost ready. I am torn between real wood, pergo types and then I read a thread on traffic master vinyl flooring at home depot. It has the appearance of wood flooring, looks like it is easy to install but best of all it is waterproof. I have two westies and they don't like to be clean!
Good Luck
sluggo is offline   Reply With Quote
Old 08-15-2008, 10:02 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My trailer had a Pergo floor installed by the PO. 3 years and 3 dogs later it still looks great. It cleans up easily.
Richard
Old 08-15-2008, 10:11 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would highly recommend a laminate flooring with a few considerations. If you are going to install laminate I suggest you remove as much cabinet and fixtures as possible and float the flooring under these items. This can be done by drilling 1 in. dia. holes at each place where the fixtures will be reinstalled. The reason I suggest removing things is it makes installation much easier in that you have less cutting and much neater in that you have no molding to detract from the beauty of the flooring. This sounds difficult at first but trust me Airstreams come apart quickly inside.
If you use laminate study the locking methods of each system. Some are quite difficult. Armstrong is a nice system and the color match was the best I found.
I only installed laminate forward of the bathroom not wanting to give up the carpet in the bath and bedroom. However if I were to install throughout the trailer I would have removed the beds, bureau, and toilet but worked around the shower.
ID:	65739   Click image for larger version
2004 Excursion 4x4
Old 08-15-2008, 10:12 AM   #5
1994 30' Excella
1973 25' Tradewind
Pergo
I like the Pergo better, what happens to it if you get a leak,does it immediately buckle up ??
Old 08-15-2008, 10:13 AM   #6
Red Bank , New Jersey
Beautiful. Wow! So nice.
CarolinePica is offline   Reply With Quote
Old 08-15-2008, 10:17 AM   #7
1994 30' Excella
1973 25' Tradewind
Pergo install
Howie, I have removed everything up front, rear bed and plant to install throughout. There is a section of carpet under the dinette that i will rip up today, my question though is is necessary to remove the dinette? I have a 30 excella.
Old 08-15-2008, 10:23 AM   #8
HowieE's Avatar
Images: 12
Take the 5 minutes with an electric drill and remove it. You will be happy you did when you are finished. Not sure if your dinette is supported with a single legs as mine is. If so I glued down a brown rubber furniture cup and placed the leg in the cup. The leg will walk around the hard flooring if left to it's own devices from road vibrations. The cup holds the leg in place while on the road.
2004 Excursion 4x4
floating floor, floor, laminate, replace
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 08:15 AM
Which Flooring???? AndyPenny Floor Finishes 29 09-18-2008 03:26 PM
Flooring arjo Repairing/Replacing Floor &/or Frame 19 04-28-2008 05:57 AM
need new flooring ? bigghpappa4 Floor Finishes 3 08-11-2006 10:41 PM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
