Old 08-28-2010, 08:49 AM   #1
1986 31' Sovereign
Houma , Louisiana
New Airstream owner with OSB floor dammage
Good Morning.
I am a new AS owner (last week) and to my disappointment and lack of AS knowledge have found a few areas of moisture damaged OSB. VERY DISAPPOINTED but continuing on. Most areas are small (less than 6" x 6") I have one area that is larger 2'x18" in near the rear storage hatches. I think your post will be a great help to me. I plan to keep you informed if your work helps me. Any suggestions would be welcomed.
ckweaver is offline   Reply With Quote
Old 08-28-2010, 10:37 AM   #2
3blessed's Avatar
2012 19' International
1986 25' Sovereign
St. Tammany , Louisiana
Welcome to the Sovereign world!
Hey ckweaver! Welcome to our world. I understand your frustration with finding evidence of leaks. Unfortunately, it seems to come with AS ownership. You'll want to definitely pull the hatch doors and seal. This should take care of your hatch area leaking, unless you also have rub rail gapping. I have resealed both areas on both sides of my AS and no longer have leaking issues. Yay! Let me know if I can help you further. I'm a Louisianian too.
3blessed is offline   Reply With Quote
Old 08-28-2010, 12:47 PM   #3
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
rot doctor
I had some small areas of water damage that left the floor spongey but they were small enough that I decided to try Rot Doctor to harden the flooring.
You need to use a respirator as it has some nasty organics. You drill small holes into the spongey floor and I mixed the Rot Doctor in a mason jar and then poured it onto the areas and let it do its magic.
It hardened the floor and I felt comfortable with the repair. I also had the trailer pressure tested, located the leaks and sealed them. three years later and still happy with the results...
Regards,
Reganzo
Reganzo is offline   Reply With Quote
1991 OSB Floor repair question capehoorn General Interior Topics 2 06-11-2006 07:13 PM
OSB For Cork Looking Flooring topazken Repairing/Replacing Floor &/or Frame 8 10-16-2005 04:38 PM
OSB as Flooring Craftsman Repairing/Replacing Floor &/or Frame 54 06-29-2004 03:29 PM
OSB for countertop base? TomW Cabinets, Counter Tops & Furnishings 4 05-25-2004 02:08 PM
Newbie A/S owner - floor repair ? Gobstopper Repairing/Replacing Floor &/or Frame 10 03-11-2003 11:38 AM
