Old 05-31-2011, 08:42 AM   #1
1969 31' Sovereign
O , Central,Florida.
Need help with Rear Bath falling out.
Hello All
I have a 1969 International Sovereign Land Yacht.
{ I still have not found the props(s) for water or air travel}
Anyway I have some bathroom issues {Rear Bath} I was wondering if someone with the knowledge could assist me?
#1 the frame is rotted it measures 5" outside & 1.5" inside & it seems very thin metal {steel} the bumper is loose & I need to fix this I was thinking of scabbing metal & was wondering if I could beef it up to (a) extend it & (b) maybe have enough room to put a endureo dirt bike on the back.
#2 the plywood in the floor is rotted & the toilet is completely free from the tank & the tank is falling down what has been the best way to fix this?
#3 I was thinking about using engineered hard wood to re floor the entire trailer {its a glue down application} leaving the original ply wood substrate.
Does anyone foresee any problems with this? Maybe coating it with poly urethane to seal it.
Well that is the major issues with this I have to get busy on it because my Wife is evicting me & I plan on moving back into my mobile mansion.
My wife used this trailer un known to me to store dog food & then the squirrels & other critters ate it to hell there was about 3 " if stuff throughout the entire unit other than some wire damage it seems OK .
needs a total sterilization after the bath is fixed.
Any help big or small is appreciated
SR66
Name:	1969 AirStream 005.jpg
ID:	131193   Click image for larger version
Name:	1969 AirStream 006.jpg
Name:	1969 AirStream 014.jpg
ID:	131195   Click image for larger version
Name:	1969 AirStream 017.jpg
Slowride66 is offline   Reply With Quote
Old 05-31-2011, 08:54 AM   #2
soldiermedic's Avatar
Florissant , USA
Ouch,
Lucky for you many people have already done this repair and detailed it here.
Top is finalizing his rear bath repair in this thread.
Abby gets some separation H
Check it out.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-31-2011, 10:23 AM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
SR66,
You have a lot of work ahead of you there. The symptoms you describe are common on long rear bath Airstreams of this vintage. It is a design flaw. It is called "Rear end separation" It has taken me five months averaging four 8-10 hour days per week to complete the repairs.
The only way to properly repair this problem is to replace the flooring with new sealed exterior plywood or marine grade plywood.
The frame is not engineered to handle any additional loading.
Good luck!
Lance
Top is offline   Reply With Quote
Old 05-31-2011, 11:09 AM   #4
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Top is right, I am afraid.
I have a simalar issue with mine, currently beefing up / repairing the frame in preparation for a total floor replacement.
Overlaying the rear floor is quicker, but it will not hold up for long at all. The shell sits on top of the floor and bolts to the frame through it, so this is a very important structural connection.
Baseman is offline   Reply With Quote
Old 05-31-2011, 11:17 AM   #5
1969 31' Sovereign
OUCH!
Well that was a fast reply time!
I have a Friend who works for a fire truck company they build them out of POLY I was thinking about replacing the floor with the poly if its strong enough it will not rot then.
I need to get this fixed ASAP for my marriage is in worse shape than the bath & I need to move into this thing.
I will go check out the links posted
SR66
Old 05-31-2011, 11:27 AM   #6
Ottawa , ON
SR66,
There won't be anything "fast" about getting this unit on the road and safe.
Read again what Top said: "It has taken me five months averaging four 8-10 hour days per week to complete the repairs."
Sell it and buy another one, roadworthy this time.
Then, you can run off to the four corners of the continent tomorrow morning!
Old 05-31-2011, 01:30 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
There are some discussions of alternative floor materials as well. They all have their trade offs. When I did my floor I looked into Nyloboard, but decided to go with good old fashioned Marine Plywood. I figure it's stronger than the original stuff, cheaper than the plastics, doesn't require any additional support, and that original floor lasted 40 years. Don't over-complicate things, you'll have your hands full with the repair as it is!
I agree with Aage though, if you want to be camping soon, unload this project to someone with lots of time, tools, and patience, and find yourself one that needs less work!
Stephanie
Old 05-31-2011, 11:26 PM   #8
Tool Hoarder
West , California
I agree with all the above. The frame is made out of 12 ga steel that is bent to make a "C". The longer trailers all suffer from this design flaw. In addition to the rotted sub floor and rotten steel you may also have some damaged outriggers. The solution is not simple or impossible.
Perhaps you could move in with a friend who has a really big driveway.
marzboy is offline   Reply With Quote
Old 08-01-2011, 01:15 PM   #9
1969 31' Sovereign
Howdy Folks.
Well I am into the last stages of dismantling .
Its been a bit tough to get on the project so many SNAFU's
Divorce /Separation / moving all my cashola going into gasoline UGH! Good grief.
Any way the metal is not so bad none of the outriggers are rotted I have filled 2 50 gallon trash cans with ..Rats nest {YUK!}
I have decided that I am going to customize the bath room the factory tub is just too small & I am not going to be washing any Barbie Dolls or little Yappy Dogs.
Its going to be a Manley Bathroom A shower & a Chitter & completely water proof I will be getting a 4' x 8' x1" sheet of Poly & sneak it between the floor & frame & then a thinner piece bent or curved toward the drain .
The Metal on the frame rails are only rotted & thinned out {rusted} foot or so .
I cut off the bumper & will stretch it so @ least 2 batteries will fit & rebuild the trunk .
I will most likely reuse the original Chit tank {black water} Although my buddy could build me a custom one no problem .
I will also relocate the dump outlet to the drivers side & re~engineer the water & electric Inlets.
I still have to test the Water heater & there is a few chewed chewed wires 12 V & 110
I will be drawing up the plans soon but its been so damn hot .
Today its 91*f with the heat index @ 111*f.
Here are some pictures of my Progress or digression {LOL!}
Oh Yea Can Someone tell me Why & is it necessary for the Grey Water Pipe to go & loop around the back of the toilet?
Just seems very weird.
Also can Y'all post links to replacement parts sites? stuff like the Black water tank Valve & stuff like that?
Thanks you all for your help.
SR66
ID:	136471   Click image for larger version
ID:	136473   Click image for larger version
Old 08-01-2011, 11:16 PM   #10
Tool Hoarder
West , California
You can extend the trunk but do not add more weight on it. The longer trailers suffer from the too much weight in the rear design flaw.
Old 08-02-2011, 06:10 AM   #11
1969 31' Sovereign
HI.
I see the frame is quite thin.
I might be able to add a bicycle rack but my dreams of being able to put a Enduro style dirt bike is not there.
IMHO the battery should have been in the trunk.
And I wonder why they did not use aluminum for the floor.
Seems like the achilles heel is the plywood flooring especially in a "WET AREA"
I am ready to go remove the tub & sink the valves are stuck .
I have had to let my sub~conscious work on this stuff for a while but now the Ideas have "POPPED" & its time for action.
Well I am off to sweat my Nutz off.
More pixs to come.
SR66
Old 08-05-2011, 02:19 PM   #12
1969 31' Sovereign
More tear out pictures.
SR66
Name:	1969 AirStream 002.jpg
ID:	136802   Click image for larger version
Name:	1969 AirStream 004.jpg
Name:	1969 AirStream 018.jpg
ID:	136804   Click image for larger version
Name:	1969 AirStream 022.jpg
Old 08-05-2011, 02:20 PM   #13
1969 31' Sovereign
Almost ready for some Construction.
SR66
Old 08-06-2011, 10:34 AM   #14
Tool Hoarder
West , California
Keep going the demo is a bitch but once you are thru it, it gets much eaiser.
New twin mattresses for rear bath billynewk General Interior Topics 4 07-31-2011 06:57 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Replacing the floor in a rear bath elkie2331 Repairing/Replacing Floor &/or Frame 4 04-04-2011 07:35 PM
1976 Rear Bath Lights Eagle & Bear Electrical - Systems, Generators, Batteries & Solar 5 03-26-2011 04:20 PM
1976 31 ft. Airstream - Rear Bath eBay Watch Airstreams on eBay 0 03-13-2011 12:40 PM
