Ifyou want to be able to camp "self-contained" it sure is. More than ever in fact: you can't just let the grey water trickle out onto the ground, since it's illegal to do that anywhere I can think of.
If you never camp anywhere but RV parks, then yes, you can do without it.
Are there Pre made tanks to go in the hole I already have?
I am going to have to add this to my sub conscious list of things to do
SR66
Okay.
The first year Sovereigns had grey tanks was 1973, usually as 1974 models. They were a whopping 10 gallon capacity, but had the advantage of easily going in the space under the floor, beneath the bathtub. You can get one to go in there, and get one up to about 25 gallon capacity, though it's not a good idea to tow any real distance with the tank full.
A better alternative these days is to get a "generic" grey tank, and mount it, say between the axles. It's a simple plumbing matter, running an ABS pipe the same diameter of what you already have up to the top of the new tank, putting in a vent, and installing a drain pipe and dump valve. If you went that route, you could simply put a Tee in the drain pipe that goes from the kitchen sink straight down to the top of the new grey tank.
I know its been sometime since I took the time to post here but its been on my mind to do so.
I have been making progress & modifications.
The Frame replacement is done minus the rear bumper Waiting to engineer & install the new custom Poop / Grey water tank.
& the floor is IN!!!
So happy about that one there
1st time in probally 20 years its buttoned up.
Yea I been slacking on it but .
I have good excuses. well at least their fun!
A whole Lotta Fun.
So Happily Divorced As of Sept. 28th 2011.
Dropped about 35 Lbs.
Bought A Harley
& got a few cuties i'm seeing .
One I really fond of.
Working in the dirt has made it hard & the cold of the winter time shut me down as far as wanting to get on my Air Dream
I also Gutted the living room area .
All the factory stuff I carefully removed & I want it sell it to someone who can use it I really hate to send it to the land fill Bathroom & living room minus anything that was trashed.
I even started cleaning her up . I literaly had to take a water hose to the interior when the cleaner hit the GACK it turned orange probally Nicotine, YUK!!
I really have to orginize my photos & find the ones for the actual repairs & post them
Now comes the trick part making the custom shower & moutning the toilet. then monting the bumper & cuting the frame back then making the trunk area
So far the POLY is great its a little heavier than wood but it will NEVER rot.
A simple plumbing matter? I'd hate to see what you call a complex one, Terry!
Inland RV sells an exact replacement 1969 black tank. You'll need someone to make you a new sheet metal pan for it since yours is likely rotted away like ours was.
__________________ Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
