Old 01-09-2019, 03:56 PM   #1
1976 31' Sovereign
Helotes , Texas
Need help with dimensions
I am about 85% finished with a new frame for my '76 31' Sovereign. I still need to weld on the outriggers for the step and the wheel wells. I am beginning to question my dimensioned drawing where it comes to the placement of the step outriggers.
I was hoping someone had a similar frame exposed so that I could get the dimension from the front edge of the frame rail to the center of the two step outriggers.
I have measured from the front of the shell to the middle of the door opening [7' 6"], but I question where or not there is significant flex to the shell.
I could also get the required dimension if someone could measure from the from of the shell to the middle of the door opening on an intact AS. It's tricky. You have to clamp/hold a non-flexing straightedge to the front square to the side. It would probably be a two-person job? I need a confirmation on the 7' 6" measurement.
Thanks in advance,
Greg
glrtex is offline   Reply With Quote
Dimensions Need Help 55AS 1960 - 1964 Globetrotter 6 11-11-2014 07:40 AM
need dimensions for skirt cutbrain Rock Guards, Segment & Window Protectors 0 05-07-2011 01:11 PM
Need 1961 Ohio Bambi dimensions! mudseason 1961 - 1963 Bambi 6 10-26-2010 11:37 AM
Need help with window dimensions cjcarter25 Upholstery, Blinds, Walls & Interior Finishes 7 06-15-2009 01:28 PM
Need help with furnace dimensions Sunset Coast Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-31-2007 08:32 PM
