Old 09-18-2006, 11:03 PM   #1
2005 19' Safari
santa barbara , California
Need frame diagram for 19' Bambi remodel
I just bought a 2005 19' Bambi and will be doing changes to interior including removing dry bath unit, replacing with a smaller wet bath and installing a larger bed across the rear. I need access to the details of the framing so as to make it easier to reinstall plumbing etc. Any help would be appreciated Charles
cmugler is offline   Reply With Quote
Old 09-24-2006, 04:42 PM   #2
2001 19' Bambi
Falmouth , Massachusetts
I've attached three .PDF files for the 19ft Bambi. They apply to my 2001 19ft Bambi, but I cannot say if they are applicable to your 2005 19ft Bambi.
915474, rev G (6/01), Chassis weldments.
915531, rev N (1/06), Chassis prep.
964465, rev H (3/06), Floor cut out.
Contact Jim Parrett at Airstream Customer Service if you want further information or drawings.
I modified my Bambi bed pedestal, freshwater and 120VAC wiring, and found that the drawings were helpful. I ended up transferring the drawings and actual measurements on my Bambi into autocad for planning the job prior to the modifications.
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
mswartz is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
