Old 05-22-2010, 03:29 PM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Need Advice re: subfloor
I am currently redoing the sub floor in my 71 Overlander International. Do I use 3/4 inch plywood or is it thicker. Some say 3/4 some 5/8?
Can someone tell me how to repair this? It is the rear U channel - it is broken in two places where it makes the bend on each side.
ID:	103102   Click image for larger version
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 05-22-2010, 03:32 PM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Next question - Is something missing here? This is where the water heater door was. It looks like someone used a drill to cut the U channel off.
ID:	103104   Click image for larger version
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-22-2010, 03:36 PM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Another Question - I have heard about the fiber optic wire in the rear lights. What is it for and where does it go. Mine is right here LOL
ID:	103106   Click image for larger version
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-22-2010, 03:42 PM   #4
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Last question - Any advice on how to repair this area? It is right behind the door for the water heater. This is also the patch that was screwed on by about 30 screws - RTVed and painted silver. LOL
ID:	103108   Click image for larger version
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-22-2010, 07:52 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
On your first question.
I would get some flat stock and cut a curved piece to drop in the channel and rivet it down. Then cut pieces to rivet to the vertical legs of the channel.
The fiber tubing ran from the tail lights to the front of the trailer at a location you could see in your rear view mirror. They carried a signal forward when the brake lights were on. A nice idea to tell you if you were missing a tail light but not a real necessity.
Short of buying a new rear quarter panel anything you do will look like a patch.
2004 Excursion 4x4
Old 05-23-2010, 04:16 AM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks. Appreciate the advice.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-23-2010, 07:49 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
My C-channel just had some cracks that I reinforced and I did exactly what Howie suggested you can see a pic here.
http://www.airforums.com/forums/atta...6&d=1263576946
SilverHoot is offline   Reply With Quote
Old 05-23-2010, 08:12 AM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The fiber optics were attached to a small box attached to the street side of the trailer. This would allow the driver to see that the trailer lights were functional while towing.
Richard
subfloor in bath help seeflash Floor Finishes 2 10-22-2009 07:13 AM
hardwood subfloor miggerysow Repairing/Replacing Floor &/or Frame 5 08-30-2008 02:07 PM
Subfloor replacement grizz814 Repairing/Replacing Floor &/or Frame 6 09-20-2006 07:16 PM
Subfloor Repair Steve Heywood Repairing/Replacing Floor &/or Frame 2 01-13-2006 07:10 PM
No subfloor? Over59 Repairing/Replacing Floor &/or Frame 5 05-13-2004 06:41 PM
